MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    Overheating?
    Originally posted by Molle View Post
    I bought the T428 in early May and since then I have tested n+1 kernels and ROMs on it. As of now the following combination represents the epitome of Android miniPC capability for media playback for me (stability, compatibility and performance in perfect balance):
    • MK908/T428 Hybrid Firmware (HFW) 1.2.1
    • kernel_molle_20130924_t428_1080p_cpu1800h_ddr720_g pu600_vsfsam
    • xbmc-20130714-6ec63cd-adddroidlibstagefright-armeabi-v7a
    The only thing I miss from v2.0.3 is the HDMI passthrough of multi-channel soundtracks. Otherwise I'd have no problems freezing my base system to the current level.
    I have no doubts you'll be able to conjure miracles with the new ROM. Hopefully you'll be able live up to the challenge, unlike Strauzo who seems to have dropped the ball w/r/t the nexus rom for T428 (which used to be my favourite ROM prior to HFW 1.2.1)
    With your Kernel my device gets hot playing a simple Angry Birds game and shuts down.How do you fix that? I miss a lot the mouse zooming feature, I can't use maps and similar apps.!!! Can someone implement it? The latest Minix stock ROM contains this feature. Otherwise I would stick to this configuration as well.
      Unfortunatly, Lewy20041 firmware 1.2.x have lot of android basic subsystem missing ex: android sync. So you must use 2.x who are not cripple and working well. You may use stock firmware 05/30 with your prefered kernel, it is also working good with less freeze .
      T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
        With your Kernel my device gets hot playing a simple Angry Birds game and shuts down.How do you fix that.
        Try to limit the max CPU frequency to 1608MHz with the included 'no-frills CPU control' app. This can be found in the settings under 'Performance'.
        NVidia Shield TV 2015 16 GB || Stock
        NVidia Shield TV 2017 16 GB || Stock
        Buy me a beer?
          Legitsu
          there is working kernels for the V3 available now lewy20041
          I can't seem to unpack your image with imgrepack so I can't do a repack with the changes needed to make it work with the V3
          I had 1.2.1 working on my V3 ages ago all you really need todo is throw the correct moduals in it and use the patched kernel I posted a a few days ago and it should be good
          please try wendal tools to unpack the firmware
          Everything is possible if we work together!
          ApkFreak
            ok so I have 1.1.2 running on the v3 seems to work fine
            2.xx is another story must be missing a lib or modual because it black-screen loops
            current devices(rockchip sucks)
            Hardkernel ODROID C1 running android kitkat
            Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
            rPi model B+ running nothing ... bricked
              hym.
              what logcat and dmesg say?
              can you get adb to work?
              ApkFreak
                Originally posted by lewy20041 View Post
                hym.
                won't boot enough to get either of those
                  2.0.4 is based on 005 minix firmware.
                  could you test if minix firmware is working for you?
                  ApkFreak
                    Hrmmm what changes did you make t428 vrs MK908 everything but the output setting should be identical correct ? I matched the partition tables added the mk908 moduals and kernel no go ...
                      if i remeber corectly just kernel and modules:"
                      please rename /system/bin/install.sh to anything and see if it boots.
                      ApkFreak
                        got it bad flash is all
                          uploading v1.1.1 with reboot probably fixed.
                          testers wanted!!!
                          Can you detail what you changed for 1.1.1 to fix the reboot issue? Wondering if we can generalize your fix to finless and jjhmod because they both still reboot randomly for me. And since I have a V3 I cannot use what seems to be your awesome firmware.
                          Thanks for your help
                            use the V3 kernel in my MK908 thread
                            I have a Idea on how I might get a working kernel for the V3 from existing sources ill post more tomorrow
                              Update?
                              Hi Lewy,
                              When will be MK908 2.0.3 Update?
                                multi widow
                                lewy what do you think about multi-window pipoM9 is the way to go?
