MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    Useless
    Lewy 2.0.3 is useless for my T428 since it keep rebooting after 1 or 2 minutes.
    T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
      Loader
      I unpack with RK29xxImageTools_v2.1 and flash using RKAndroidTool but same rebooting. I noticed when using batchtool bootversion was 1.20 but with RKandroidTool boot is 1.24. I will wait for other member to see if I am the only one with this reboot issue.
        Which is better?
        Originally posted by BigND View Post
        I see. Not the best available at the moment.
        What do you suggest? Which is the best now?
          hi lewy20041, I tested the new ROM "T428_HFW_2.0.3_720p_1080p",
          but I also have the same problem of random reboot.
          tested with :
          T428_HFW_2.0.3_720p_1080p + Original kernel
          = random reboot.
          kernel kernel_20130902_101055_phja_t428_720p_cpu1800h_ddr 600_vsfsam.img
          kernel_20130902_101055_phja_t428_1080p_cpu1920h_dd r720_vsfsam.img
          = random reboot.
          T428_HFW_2.0.3_720p_1080p + kernel_t428_phja_20130802_vsf_ocl_720
          = random reboot.
          I tested the new ROM for Minix neo X7 "Minix_x7_HFW_2.0.3_1080p" in the tronsmart T428,
            have to confirm reboots on t428 with quality 2a psu - not getting behind boot animation! v2.0.3 for k-r42 booted and was working besides wlan and stuff like this...
              In settings/Performance :
              I noticed that the clock frequency is,
              Max Clock: 1.8 GHz
              min clock: 1.2 GHz
              Is this normal?
                2.0.3 problems
                So far the problems that I experienced:
                -random reboot every 5 minutes. I changed the performance back to 1.6 Ghz from 1.8 Ghz but same reboots happened
                - camera does not work (c170) saying, "gallery has stopped"
                - 1080p video choppy from sdcard, but if I restart my 2 years old Samsung Tv set the movie playback becomes smooth!!! So there is something with the HDMI output!
                - wifi connects at only 19 Mbit/s instead of the standard 45 Mbit/s. I restarted the router but no luck.
                - network performance poor due to wifi speeed
                All in all it's a step back comparing to 1.2.1
                Keep up the good work4
                  For me the "kernel_20130902_101055_phja_t428" create problems with Tronsmart T428.
                  Only the kernel:
                  "kernel_t428_phja_20130802_vsf_ocl_720"
                  "kernel_t428_phja_20130802_vsf_ocl_1080"
                  works perfectly in Tronsmart T428 (for me).
                  Lewis is it possible to make a ROM "T428_HFW_2.0.3_720p"
                  with "kernel_t428_phja_20130802_vsf_ocl_720"
                  without switch resolution, thank you in advance.
                  Maybe the problem comes from "switch resolution" ?
                    Can't get mine past the opening animation, just constantly reboots. Device is cold so not an overheating problem.
                    Your device must be made of sterner stuff Lewy!
                    Donate to Finless
                      Hi lewis, I allowed myself to change your ROM "T428_HFW_2.0.3_720p_1080p" ,
                      to see if I could use only with "kernel_t428_phja_20130802_vsf_ocl_720".
                      I apologize if I could not.
                      Now with the changes :
                      Now the boot is correct, +/- 30 sec
                      Boot Recovery = OK
                      WIFI = OK
                      bluetooth = OK
                      LAN (RJ45) = OK
                      Score antutu in landscape = 20623 ( for me is a new record ), 4x1800 MHz in kernel 720
                      Max Clock: 1.8 GHz
                      min clock: 312 MHz
                      VIDEO in 1080p :
                      MXPro, BsPlayer ( in SDcard EXT ) = ok
                      video player natif = problem ( bizard )
                      video streaming ( youtube ) 1080p = OK
                      After 1 hours 30 Min of use the Tronsmart T428 :
                      no bug, no reboot, until now,... no break wifi
                      the Tronsmart T428 is not hot ( normal)
                      I have to say, I do not resolve problems , I have nothing optimize, just remove the switch resolution,
                      and put the "kernel_t428_phja_20130802_vsf_ocl_720", I'm not developer.
                      Tanks Lewis for the new ROM, and good work for the rest.
                        hym...
                        i fuc... something probably, will check and try to fix the problem.
                        download link in first post pulled down.
                        i will upload new ver, will need some testers.
                        Everything is possible if we work together!
                        ApkFreak
                          PICK ME!
                          Originally posted by lewy20041 View Post
                          hym...
                          I'll be a test subject!!
                            i have a question.
                            do anybody know if kernels i used have nfs support?
                            i activated nfs script at boot and i rememberd that it was cousing reboots some time ago for some devices.
                            if firmware im uploading still will get reboots i will know what need to be done.
                            ApkFreak
                              ok
                              please test v2.0.3.
                              http://d-h.st/Cus
                              ApkFreak
                                AW: MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
                                does that mean we get either reboots or ntfs support?
                                tapatalked from MK908v3
