MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    Test MK908 Logitech C270 HD Web Camera
    T1/ C270 Test: MK908 v1.2.0 720p kernel - FAIL
    T2/ C270 Test: MK908 v1.2.0 Change Kernel = mk908-jjhkernel-v3.5-720p-cool - PERFECT
    T1/ Skype - FAIL
    T2/ Skype - OK
    T1/ Antutu test 18104 (SD Card Write Speed 10.4MB/s)
    T2/ Antutu test 18397 (SD Card Write Speed 12.7MB/s)
      I have a USB sound card connected to my T428 (through a USB hub). Each time I reboot the device, sound output defaults to "Generic USB Audio Device" instead of "ROCKCHIP HDMI".
      Is there a way to force HDMI audio to be the default output device?
      NVidia Shield TV 2015 16 GB || Stock
      NVidia Shield TV 2017 16 GB || Stock
      Buy me a beer?
        Will this rom work on an RKM MK802IV with the AP6210 wifi chip.
          Re: MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
          Well I'm looking for the same thing. will this rom work for mk802iv with Sam's kernels?????
          Sent from my GT-S7562 using Tapatalk 4 Beta
          FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
          https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
          My Plexi MK802IV mod
          http://www.freaktab.com/showthread.p...xi-MK802IV-mod
            Very nice rom! Thank you very much.
            I can now use Skype with audio & video from my Microsoft Lifecam VX-5000.
              Hi, will there be 1080p kernels for the 1.2x versions?
                Working BT keyboard and VPN?
                Could somebody please confim if Bluetooth external keyboard and VPN work on the 1.21 rom/kernel (mk908 v.3 stick).
                Thanks in advance.
                  Thanks in advance.
                  I confirm, try one of these kernel: http://www.freaktab.com/showthread.p...ll=1#post91541. Unfortunately, it's slower than hoabycsr kernels, and still cpu scaling doesn't work ;/
                    guys can this rom work with mk802iv with sam123 kernel. or that is not possible. sorry for repeating but i can`t find an answer to this anywhere. thx
                      well as no one is answering (these days this is usual) , i can answer to this myself. i flashed lewy rom to my mk802iv and wasnt working. after that i unpacked the img file and flashed one more time, but this time i used almost everything from neomode 1.3 rom and only the system.img from lewy and well surprize its working very good except for one thing when i turn off the device it reboots. if anyone here has the same problem and has found a solution pls share it so that we all can benefit from it. thx
                        Dead download links?
                        Originally posted by lewy20041 View Post
                        This firmware is based on the latest one relised by minix.
                        My website:
                        http://www.apkfreak.com
                        Changelog:
                        Beta
                        (some bugs may be present)
                        v1.2.1
                        -all futures of 1.2.0
                        -firmware migration (!there might be some bugs due to hevy changes, please post your findings!)
                        -new shutdown menu
                        -power off working as it should
                        -new base firmware (latest minix firmware)
                        -fixed setting/firmwork-res strings
                        -screenshot button can be turned off/on in settings (!change location of screenshot to sdcard!)
                        -autohide statusbar option in settings>display
                        -new 720p kernel to prevent reboots (from "ugoos ut1")
                        -"special" removed from HFW Settings, "Dev Settings" added insted
                        -alot fixes, tweaks etc.
                        Stable
                        (last ver based on stock k-r42 rom)
                        v1.2.0 Final
                        -root
                        -spoofed as Galaxy SIII
                        -gamepad button on statusbar opens "Tincore Key Mapper" (you can play games like bad pieggies with mouse)
                        -build.prop tweaks
                        -gameloft fix
                        -2gb app space
                        -changed bootanimation
                        -deleted usles apps
                        -better webcam support (logitech webcams like c525 wasnt working before, now it works like a charm)
                        -bootsound suport (put any .mp3 into system/media and rename it to android_audio.mp3 it will be played at bootanimation screen.)
                        -auto install advancedsettings.xml for smooth 1080p videa playback in XBMC
                        -Default launcher option under HFW settings>Special (Chouse which launcher you want to use as default)
                        -nfs support
                        -init.d support
                        -added HFW version under settings>about device
                        -added some nice apps:
                        *ES Explorer (ver. before layaut change)
                        *Wallbase
                        *Youtube for GTV 1.6 (due to login problems on 1.7.1)
                        -new settings (HFW Settings)
                        *Special (Conect to PC; Download XBMC)
                        *Performance (you can change CPU clocks)
                        *Equalizer (need some testing)
                        *SuperSU (now it wil show here insted of app drawer)
                        *Terminal (//-//-//-)
                        -unlocked hiden options:
                        *Bluetooth
                        *Accessibility
                        -new modules:
                        *ntfs.ko added
                        *md4.ko
                        *pl2303.ko
                        *crc-itu-t.ko
                        *isofs.ko
                        *cdrom.ko
                        *udf.ko
                        *isofs.ko
                        *btusb.ko
                        *tun.ko
                        *virtual touchscreen.ko (720p)
                        -some visual changes
                        -modules package [provided with the rom package]
                        -disabled hdmi check for apps like "Xfinity, HBO GO"
                        -new visual (system bar etc.)
                        -power button on system bar
                        -clean home screen from usles shourtcats and widgets
                        -new wallpaper
                        -ic_sysbar_highlight changed to cyan
                        -ic_sysbar_lights_out_dot changed to transparent (no dots on status bar when waching movie on mx player etc.)
                        -deleted search bar from home
                        T428
                        v1.2.1 Beta
                        Freaktab-Cloud 720p
                        v1.2.0 Stable
                        Dev-Host 720p
                        v1.1.2
                        Freaktab-Cloud 720p (New Kernel)
                        Freaktab-Cloud 1080p (New Kernel)
                        MK908
                        v1.2.1 Beta
                        Freaktab-Cloud 720p
                        v1.2.0 Stable
                        Dev-Host 720p
                        v1.1.2
                        Freaktab-Cloud 720p
                        Regards
                        Lewy20041
                        Thanks go to:
                        leolas (for his help whenever i need)
                        phjanderson (kernels for t428)
                        hoabycsr (kernels for mk908)
                        dl links not working, are there alternates?
                          All link is work ! Delete hosts file or rename from /etc/
                          adf.ly is blocked.
                            Lewy is there a way to spoof the device as a tablet and not as a phone because some games get stretched and can't be played. Other than that your rom is working great on the mk802iv the new one. Thanks
                              Mk908 results
                              I flashed v1.2.1 Beta to my MK908 today and the performance is very good. Video playback is the best I've seen since getting my MK908 some weeks ago (and several ROMs). Antutu score is 18614. The only problems I've run into is Wi-Fi, which works but not well considering my Mini PC is two inches away from my wireless router, Ethernet works well. Also, Bluetooth turns on and sees two of my devices but I am unable to pair with either of them. I never saw these issues with any of the other ROMs I had tried. Question, can the game controller icon on the bottom bar be removed, I don't use my Mini Pc for gaming and I would like to keep the bottom bar as clean as possible? Thanks.
                                T428 v1.2.1
                                antutu score 19,086 good work lewy
