Nfs is not working...I get "no such device" ..ugh...what the deal? wish these rom would consistenly work
MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
Wifi speed
Hello everybody !!
Last week I got a T428 which until now, I really like it. My only complain is with it's Wi-Fi power. Although the connection is stable and it shows good-excellent reception the wi-fi speed is pretty low and unstable.
I have an Asus RT-N16 router (1meter away from the T428) that acts also as a NAS server. The router is set on N only with 40Mhz channel width. With my PC, I get 6MB/s transfer rates. With my android phones and tablet I get transfer rates up to 1.8MB/s while the T428 fluctuates a lot between 250K/s-750k/s. I never saw a higher speed than 800k/s. This limits a lot to watch x264(720p) files from the NAS server which need at least 1MB/s stable speed.
Do you see any difference with this firmware? I now use Finless 1.5a.
Originally posted by Juliorm View PostNfs is not working...I get "no such device" ..ugh...what the deal? wish these rom would consistenly work
Originally posted by BigND View PostNFS IS working! Check your parameters. Several pages before in this thread I was trying to get my NFS shares to work. There you can find some tips.
su
mkdir /mnt/nfs
failed read only filesystem
I'm not sure why it's not working, when I try to use a directory that already exist such as sccard/movies it gives me an error that states no such device....it's frustrating because on last rom I loaded it worked after many attempts but there was no good reason why it did work..commands didn't change.
If I use smb movies are all chopping and sounds horrible.
If I try to connect thru xbmc via NFS it finds and connects fine but the movies are chopping that are greater than 5 gigs
I would appreciate some help adviseLast edited by Juliorm; 25 August 2013, 14:47.
Originally posted by georgetheman View Post
It is for Windows, not Android. He needs an Android module.(TL-WN-723N/725N)
Originally posted by Juliorm View PostThanks BigND, I'll found the exchange you had with lewy...I'm using terminal to submit the commands. I get the following error:
su
mkdir /mnt/nfs
Originally posted by lewy20041 View Posti have k-r42 only and its working here.
i will upload a script for you to test.
give me couple minutes.
edit:
i think i forgot 1 symbol in the post before.
change !/system/bin/sh to #!/system/bin/sh
it should work now
sory for that
my bad;p
Enter SU - It gives terminal permission
mkdir /mnt/nfs - it fails because system is read only filesystem.
To bypass the mkdir /mnt/nfs step I created directory folder using Root Explorer, giving it 0777 permission.
I've double/tripled checked that my nfs server is running ok, version 3. I can find it using nfs thru XBMC but xbmc has its own issues. point only that if it is accessible thru xbmc so it should also be using terminal.
When I issue the following command I get "no such device"
busybox mount -o rw,intr,soft,nolock 192.168.1.128:/homeserver/videos /mnt/nfs
When I tried to uncomment the 05nfs file, it lets me edit it but will not let me save it.
I saw your comments before to BigND regarding permission but so I'm thinking that maybe my issue but how do I change the system permission so it can write and save files? This way I could just use the 05nfs file to load my nfs server instead of using terminal.
I'm at a loss as to what I am doing wrong or what is wrong with the permissions set on this rom. I've checked the web and it's all very cryptic as the how to resolve.
Please any help you can give would very much appreciated! Thks
in terminal type
su
mount -o rw,remount /dev/block/mtdblock8 /system
do what you need to do and then type
mount -o ro,remount /dev/block/mtdblock8 /system
if this dont work for you change directory in my script from /mnt/nfs to /sdcard/nfs
also mkdir to /sdcard/nfs
it should workEverything is possible if we work together!
DeletedMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by lewy20041 View Postin terminal type
su
it should work
mount: mounting 192.168.1.128:/homeserver on /sdcard/nfs failed: no such device
If I use es explorer or root explorer the directory /sdcard/nfs exist but it is empty
so I'm not sure which "no such device" is referring to?
I've doubled checked that I type every bit of text correctly but I'm lost as to why it is not mounting or what it means as "no such device".
Any suggestions?
type in terminal lsmod
and see if nfs module is loadedEverything is possible if we work together!
NFS
I dont know anything about NFS but fond something maybe of interest
Note that the mount command that comes with the tablet does not have NFS support. The mount from the BusyBox app does contain NFS support (although not NFSv4). To run the mount command from the BusyBox install you need to use /system/xbin/mount. The command should look something like this:
/system/xbin/mount -o nolock -t nfs hostath localpath.
T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
There are currently 1449 users online. 0 members and 1449 guests.
