MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
check /mnt/ex_sdcardEverything is possible if we work together!
Originally posted by lewy20041 View Postcheck /mnt/ex_sdcard
I'm looking forward to try the new 1.2.0Last edited by diegocaxudo; 16 August 2013, 06:20."Success is a lousy teacher. It seduces smart people into thinking they can't lose."
- Bill gates
Originally posted by redbluegeo View PostI flushed the ROM yesterday and since then I have no problems. Thanks for your work!! I have a question. Which is the best app to control the t428 from my android phone??
https://play.google.com/store/apps/d...teclient&hl=es (client)
https://play.google.com/store/apps/d...teserver&hl=es (server)"Success is a lousy teacher. It seduces smart people into thinking they can't lose."
- Bill gates
it will work on next ver.
100%Everything is possible if we work together!
Originally posted by diegocaxudo View PostI always use droidmote because of all its features
Thanks for the help!
Is there a good app that ia also free??
which kernel for mk908/t428 do you want me to use in nex ver?
please post back with links.
it will be avilible tomorow.
changelog:
v1.2.1
-firmware migration (!there might be some bugs due to hevy changes, please post your findings!)
-new shutdown menu
-power off working as it should
-new base firmware (latest minix firmware)
-fixed setting/firmwork-res strings
-screenshot button can be turned off/on in settings (!change location of screenshot to sdcard!)
-autohide statusbar option in settings>display
-new 720p kernel to prevent reboots (from "ugoos ut1")
-new modules
*md4.ko
*pl2303.ko
*crc-itu-t.ko
*isofs.ko
*cdrom.ko
*udf.ko
*isofs.ko
-"special" removed from HFW Settings, "Dev Settings" added insted
-alot fixes, tweaks etc.Everything is possible if we work together!
Kernels
Hi, Lewy20041!
Once again, thanks for your hard work on ROMs for T428.
As for your question about kernels it would be just great if it is possible to anyone to flash kernels into 1.2.1 !!! If it's not than do as usual phjanderson's vfix ocl 720p and 1080p, please.
BTW, description says that the new kernel from ugos is already in there. Is it overclocked and vsync fixed? Or it's not THAT kind of kernel?
now its kernel jail free;p
ugoos kernel is just for k-r42, its just to prevent reboots on this device.
you can flash it with which kernel you want.
also i made a ver for minix x7
so for hasty ones its allredy uploaded there
so you can edit it to work on your devices.
proper roms for mk908/t428 tomorowLast edited by lewy20041; 17 August 2013, 00:01.Everything is possible if we work together!
[QUOTE=lewy20041;86891]which kernel for mk908/t428 do you want me to use in nex ver?
Hi Lewy20041, My choice is simple, update T428 1080P, version 1.1.2 with NFS option. Version 1.1.2 is running excellent for me, the only item I need is the Nfs option so that I can connect to my media server allowing me to what hd movies without a hassle! I guess the other item would be any instruction I may need to make the connection to host nfs.
Thanks a bunch
Julio
There are currently 1975 users online. 0 members and 1975 guests.
