MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
on mk908 or t428?Everything is possible if we work together!
hym...
i think i know whats may be the couse of this.
will try to fix this in next ver.
can someone try to insmod nfs modules from first post?Everything is possible if we work together!
test on T428_HFW_1.1.2_VF_720p :
Overclock à 1800 MHz (x4)
score antutu = 19032
it is a little hot, but it's still good
Overclock has 1608 MHz (x4),
score antutu = 18976
for me, this is a good configuration
1.1.2, 720P, MK908
Good:
Wifi - Best rom yet.. double the speed of any other rom.
YouTube - No Buffering
Bad:
Reboot - It seems to over heat after moderate/high usage and reboot
Slow - Its seems sometimes there is a latency before an app does anything especially on first load up.. then it's fine.
Originally posted by jadeboy View Post1.1.2, 720P, MK908
Good:
Bad:
go to settings>performance and lower the cpu clocks.Everything is possible if we work together!
Upgrade from 1.1.1 to 1.1.2 & usb issue
is there any way to update to the last version without losing everything?
I have a multiusb hub, but i have big trouble to get my 2Tb hdd work: this my config:
(my multisub is unpowered)
- mk908 attached to the mutiusb
- adapter for remote mouse/keyboard (it working fine)
- 2tb western digital hdd (powered by itself, every light is ok !!!filesystem EXT2 eithout journaling!!!)
is a filesystem issue?
if yes why i cannot see any usb pendrive? (128MB, 4Gb and so on...)
insmod auth_gss.ko - OK
insmod lockd.ko - OK
insmod nfs.ko - ERROR
"insmod: can't insert 'nfs.ko': unknown symbol in module or invalid parameter"
Unfortunately!
Unfortunately!
Originally posted by lewy20041 View Postcan you try the ones from this package?
http://d-h.st/tMl
I'm using mk908 with HFW v.1.1.2 1080p.
There are currently 3104 users online. 5 members and 3099 guests.
