MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    Originally posted by lewy20041 View Post
    which kernel for mk908/t428 do you want me to use in nex ver?please post back with links.it will be avilible tomorow.changelog:v1.2.1-firmware migration (!there might be some bugs due to hevy changes, please post your findings!)-new shutdown menu-power off working as it should-new base firmware (latest minix firmware)-fixed setting/firmwork-res strings-screenshot button can be turned off/on in settings (!change location of screenshot to sdcard!)-autohide statusbar option in settings>display-new 720p kernel to prevent reboots (from "ugoos ut1")-new modules *md4.ko *pl2303.ko *crc-itu-t.ko *isofs.ko *cdrom.ko *udf.ko *isofs.ko-"special" removed from HFW Settings, "Dev Settings" added insted-alot fixes, tweaks etc.
    For MK908 use the latest kernel from hoabycsr.
      The link being - http://www.hoaby.com/android/mk908-jjhkernel-v3.3.rar
        First post updated with new firmware.
        Everything is possible if we work together!
        ApkFreak
          lewy20041 hello, thank you for the new ROM 1.2.1.
          I will test the ROM and give my report, if there are bugs.
          A big thank you for your work.
            Thank you,
            Reboot not working, also MXplayer Pro won't play with HW (impossible to play with HW decoder) but play fine HW+. 720p are fine both from network and sdcard, 1080p stutter (but it always did). Playstore work fine (I have all apps I use).Real good firmware
            T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
              Hi Lewy20041, I just downloaded from 1st post the T428 1080p v1.1.2 rom. Checking the last modified dates, this has not changed since 8.5.13. Did you post a new one for the T428 1080p with NFS? Please let me know when it will be available. Thanks
                Download 1.2.1 720p in first post and try NFS it does not mater resolution if you want to test it.
                  Thanks for the info but I would like to also see it in the 1080p as well since that is the one I have loaded. I will test with the 720p first and hopefully works well. Thks
                    All three decoders work on my T428.
                    NVidia Shield TV 2015 16 GB || Stock
                    NVidia Shield TV 2017 16 GB || Stock
                    Buy me a beer?
                      I don't know why but you are right some of my files play with HW, mainly tv show, but my movie not. I didn't have that behaviour previously. Maybe cause by bitrate or mkv format...
                        Originally posted by Moulin1980 View Post
                        could you settle for the Hybrid ROM Firmware (HFW) 1.2.1, the kernel of pj anderson "kernel_t428_phja_20130802_vsf" For Tronsmart T428
                        I suggest picking the overclocked kernel instead. The 1080p version runs nice and cool and you can use the performance settings to cap the max frequency to the standard 1,608GHz if you don't feel like oc'ing.
                        I would also suggest defaulting to ondemand governor and noop i/o scheduler.
                        Buy me a beer?
                          Hi all, my first test with the Tronsmart T428 and the ROM 1.2.1,
                          Résolution 1920x1080p-60, OC 1608 MHz :
                          Vidéo in (sdcard EXT) "h264_1080p_hp_4.1_40mbps_birds.mkv",
                          with MX PRO IN HW and HW+ = OK for me, good vidéo
                          Reboot working for me, use "holo reboot.apk" is (free)
                          I click on all the options in the setting, no bugs.
                          the stick Tronsmart T428, not hot, excellent.
                          ( one hour of use, no reboot bug )
                          Antutu = 18991 ---> OC ( x4 1600 MHz ), best score
                          great job for the ROM (lewy20041), thank you very much.
                            I just executed the AnTuTu benchmark with phjanderson's oc'd 1080p kernel for T428 and the following settings:
                            • CPU overclocked to 1,8GHz
                            • ondemand governor, noop i/o scheduler
                            • locked landscape mode
                            • output resolution set to 1920x1080p-50
                            Score: 17442
                            This is absolutely astounding! My previous record with a 1080p kernel was about 13000. Also my previous all-time record was 16368 with the Nexus Multi-Window v1.2 combined with the kernel from the Finless Alpha ROM (720p).
                            Furthermore, the device didn't even heat that much during the process. I kept my hand on it the whole time and would swear that the plastic cover never got warmer than ~45C.
                            I'm actually ... speechless (in a euphorically positive way for a chance).
                            to Minix for the superb firmware
                            to lewy20041 for the customised ROM
                            to phjanderson for the excellent kernels for T428
                            Buy me a beer?
                              Titanium Backup never running
                              thanks for the new rom, unfortunately, titanium backup does not work.
                              Best kernel is HFW 1.1.2 1080p Antutu 17658.
                              Original from Store works - no idea why my 3 old versions no longer run.
                              Im waiting for the new 1080p kernel.
                              Thank you for your work
                                That's odd. I haven't tried restoring stuff yet but backing up, at least, works as usual.
                                Buy me a beer?
