MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    Originally posted by lewy20041 View Post
    1. yes. i forgot about it;p
    2. i dont useing this so i will look into it
    when i will have more free time.
    ui is in 1080p just dpi is difrent.
    do you want that small icons?
    google lcd density
    if you still will like to change that pm me i tell you how.
    Well, I don't see the point in 1080p kernel without full HD ui. The video is real slow and unstable in 1080p version. I'm going back to 720p kernel. Alas, despite of quad core, T428 still can not run fullHD video smoothly.
    BTW, lewy20041, do you use modified phjanderson's video vsink fixed kernel in 1.1.2? I ask because video in new version seems to have some jitters and frame skipping. I think in 1.1.1 video was much smother.
    So which kernel do you use in 1.1.2 for T428.
      Phjanderson posted new version of his vsync fixed kernels for T428. Here: http://www.freaktab.com/showthread.p...ll=1#post83018
      Do you use them in your rom?
        i used stock kernel.
        will use the kernels you pointed in next ver.
        also you dont understand something about the ui.
        its rendered at 1080p only difrence is that icons arent small.
        google dpi, lcd density.
        is not 720p ui;p
        Everything is possible if we work together!
        ApkFreak
          is not 720p ui;p
          I do understand the difference now, thank you. I just mean that still rk3188 at this point perform quite poor in 1080p.
          Now I see why the video in 1.1.2 is not perfect. Please, release your rom with fixed vsync kernels, soon! I will desperately wait for it!
          Thank you!
            i will do this tomorow
            ApkFreak
              OK, will look into it. You're DA MAN! ;p
                I love your rom, nice job!! The first one for me that can stream HD movies from my Windows computer, with XBMC!
                I found one little bug, when i am logged in in the stock Youtube app and click on my profile in the app, it crashes.
                  So far so good
                  I have been running V1.1.2 for just over 10 hours and trying every function I can think of without any problems. The device is a Tronsmart Mk908.
                  720P is running very nicely. WiFi is as near identical as far as I can see to the stock rom and I had no problems with that. All my Google Play app purchase's work fine. Volume up/down is O.K. Temperature of the Mk908 unit playing over 6 hours of 720P remained reasonable and stable. Have not bothered with the 1080P side as I dont use this anyway.
                  Actually works better than my Nexus 10 with 4.3 when it comes to HW+ playback . But thats an issue for Android 4.3 and app devs.
                  You are certainly on the right track with this Lewy and I appreciate your work.
                    thats youtube for gtv 1.7.1 bug on our devices.
                    you can login but you want be able to see your profile.
                    cant help with this yet
                    ApkFreak
                      T428 updated with video jitter fixed kernels.
                      ApkFreak
                        hi lewy20041, the new KERNEL is "kernel_t428_phja_20130802_vsf" of phjanderson ?
                        - If yes: it is :
                        "kernel_t428_phja_20130802_vsf_720.img" ?
                        or
                        "kernel_t428_phja_20130802_vsf_ocl_720.img"?
                        - If not, excuse me.
                          Are you going to update the MK908 in the same way?? I'm getting jerky HD video (v1.1.2), mostly on action-related scenes, but noticeable always. SD quality is fine.
                          Still, this is the best ROM for me. Thank you!!
                            test on T428_HFW_1.1.2_VF_720p :
                            score antutu = 19032
                            Overclock à 1800 MHz (x4)
                            it is a little warmer than the PREVIOUS ROM ( but it's good ), it's normal in 1800 MHz
                            beautiful ROM, Thanks.
                              Real good firmware!
                              Thank's lewy20041 for that firmware with synch patch. To me it is the best rom I tried for month. Just one thing I want to do and do not know how. When installing new apps or upgrading preinstall icon are colorful and don't match the blue one, so I try to install original app launcher in folder of firmware with no success. Is there a way to restore original icon color? I also try Nova but preinstall app remain blue.
                              T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                                nfs modules in first post to download.
                                in next ver nfs support out of the box.
                                thanks leolas for this
                                please post feedback if its working for you.
                                1. insmod sunrpc.ko
                                2. auth_rpcgss.ko
                                3. lockd.ko
                                4. nfs.ko
                                mount share using terminal with comand:
                                Code:
                                mkdir /mnt/nfs
                                busybox mount -o rw,intr,soft,nolock [B][COLOR=#006400]192.168.1.102[/COLOR][/B]:/mnt/HD/HD_a2 /mnt/nfs
                                ApkFreak
