MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
T428 v1.2.1 antutu reboots after a few seconds..... today's upgraded antutu version goes to 43% then reboots. btw. has anyone cwm recovery in his T428? i had cwm recovery in finless rom 1.5 and strauzo's nexus rom. same cwm recovery image doesn't seem to work with HFW1.2.1. it hangs right after the reboot sequence.
Does anybody know if this rom is compatible with v3 of MK908?
Thxhttp://www.MayBeSmart.info
The Best Tutorial Site!!!
Originally posted by bloatman View Postantutu score 19,086 good work lewy
Because 18400 is the max I can with Phjanderson's latest oc'd 1080p kernel at 1920MHz/720MHz.
v1.2.1 Beta
Freaktab-Cloud 720p
Originally posted by tdriver View PostT428 v1.2.1 antutu reboots after a few seconds..... today's upgraded antutu version goes to 43% then reboots. btw. has anyone cwm recovery in his T428? i had cwm recovery in finless rom 1.5 and strauzo's nexus rom. same cwm recovery image doesn't seem to work with HFW1.2.1. it hangs right after the reboot sequence.
- kernel_20130902_101055_phja_t428_720p_cpu1800h_ddr 600_vsfsam: 18614
- kernel_20130902_101055_phja_t428_1080p_cpu1920h_dd r720_vsfsam: 19623
MK908 Video issue
I am very new to this great new world and I am very excited about it. I am having an issue with this ROM on my stick. When I am at the home screen, any time I move the mouse my video starts to flicker, and then when I move the mouse a lot my video cuts out all together. I am navigate my way to the settings screen and it doesn't happen. Has anyone else seen this issue? Am I missing a custom mod that I should add to my SD card to load at boot up?
Thank you in advance,
lazyDonkey
So a quick update, I guess I am a little too excited. What it seems to have been was I wasn't close enough to a wall outlet so I had to put a USB extention cable on the power. So my guess is that it wasn't getting enough juice.
by far the best rom for T428 V1.2.1.
-much faster than anything else.
-not dropping frames in video playback
-stable wifi transfer speed. This is the only ROM that was able to pass 1.1MB/s transfer speed from my NAS. Because of that the 720p MKVs that I have on my NAS are played whitouth issues. This is the only ROM that was capable of that.
-Over 20000 points in Antutu v4 on 720p kernel
My only issue so far was not able to install RK remote like I said above. The app does not install with no error messages. I used the RK remote in the Finless ROM to play Real Racing 3 with my android phone as the gyro controller + the brake button.
v1.2.0 runs almost perfect on my CX-919. There are two small mistakes though:
I can't get Flash Player working in this rom. Flash works great using Neomode's rom but no matter which flash version I try, it doesn't work here. Which version are you guys using?
Second problem is that widgets don't work at all. Neither the included nor downloaded ones.
Other than that, this rom runs surprisingly well on my CX-919 and it's the only one which supports my Logitech webcam.
There are currently 7149 users online. 2 members and 7147 guests.
