MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    Originally posted by Tabber2013 View Post
    v1.2.0 runs almost perfect on my CX-919. There are two small mistakes though:
    I can't get Flash Player working in this rom. Flash works great using Neomode's rom but no matter which flash version I try, it doesn't work here. Which version are you guys using?
    Second problem is that widgets don't work at all. Neither the included nor downloaded ones.
    Other than that, this rom runs surprisingly well on my CX-919 and it's the only one which supports my Logitech webcam.
    If I remember right, Flash only works with the stock browser. Not compatible with Chrome or others (I think).
    TV Stick: MK808 // Tronsmart T428
    ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
    CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
    Recovery: ClockworkMod
    Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
    Phone: Samsung Galaxy Note II
    ROM: Whompasaurus v4.2
    Kernel: Persus
      Using Neomode's Custom Rom 1.3, Flash also works in Firefox. That's why I found it rather weird that it's not working in Lewy's Rom.
        Originally posted by ionutzica View Post
        flashed this but Google TV screen loop over and over... how can I solve this?
        I have the same issue with my 908 v3 stick with v1.2.1 Beta. Any help is appreciated.
        Thanks.
          Thanks.
          I think this rom is not compatible with V3 of MK908!
          http://www.MayBeSmart.info
          The Best Tutorial Site!!!
            @lewy20041 Are you still looking to build on this? I noticed you posting in another forum looking at a 5.1 pass through workaround and was hoping that would be part of your next step.
            Using my ipad so apols for any shitty ios spelling 'corrections'
            Donate to Finless
              hi guys
              when i was trying to set up a vpn on my device it asked me to put a pasword for the device.
              now i want to remove that password but i cant find it nowhere in the security section of the settings.
              im using lewy 1.2.1 beta rom
              how do you show all settings in the security section, is it possible
              Sent from my GT-I9300 using Tapatalk 4
              FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
              https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
              My Plexi MK802IV mod
              http://www.freaktab.com/showthread.p...xi-MK802IV-mod
                CWM Recovery
                lewy20041, Why your ROM v 1.2.1 does not work with the CWM recovery ?
                  ask me.
                  im on it with leolas so new ver should work:"
                  Everything is possible if we work together!
                  ApkFreak
                    Can you shed any light on where the problem lies with the current version?
                    NVidia Shield TV 2015 16 GB || Stock
                    NVidia Shield TV 2017 16 GB || Stock
                    Buy me a beer?
                      probably recovery and misc i used was from difrent device:"
                      its ok but not when you traying to use cwm:"
                      ApkFreak
                        Fair enough. Looking eagerly forward to the next version.
                        Buy me a beer?
                          When do you plan to release the next version ?
                            Hi all, NuN 70, I tested the method leolas, works perfectly in the tronsmart T48 (T428_HFW_1.2.0_Final_720p) and (T428_HFW_1.2.1 beta).
                            I had, the problem with APK (holo Reboot_v0.9.3 and reboot), no reboot recovery.
                            But with APK TERMINAL copy:
                            su
                            reboot recovery
                            and everything works fine, I did backup, and restore the backup, no problem.
                            HI Molle, is that the kernel (20130910_t428_1080p_cpu1920h_ddr720_g pu798h_cfgia_vsfsam)
                            works better than (kernel_t428_phja_20130802_vsf)?
                            I tried for hours, to produce a "kernel phjanderson 20130910", with Marvin, but it's too difficult for me,
                            Is it worth it to create a new kernel?
                            or
                            the kernel (kernel_t428_phja_20130802_vsf) is enough?
                              or
                              Tweaking and building one's own kernel build can be ... satisfying. But the truth is, I'm not really creating anything new. The major kernel tweaks and build tools are all Phjanderson's and Sam321's creations. I'm just playing around with existing settings trying to find the best balance between compatibility, performance and stability.
                              If you wish to continue using Peter's builds, I recommend the following: 'kernel_20130902_101055_phja_t428'. My build has some settings different from Peter's but I will not call either better or worse than the other. Everyone has their own preferences. I just hope my builds will make someone's device work a little bit better than before.
                              Buy me a beer?
                                tanks Molle for the response, but how to compile files, ex :
                                kernel_20130902_101055_phja_t428_720p_cpu1800h_ddr 600_vsfsam.config
                                kernel_20130902_101055_phja_t428_720p_cpu1800h_ddr 600_vsfsam.img
                                kernel_20130902_101055_phja_t428_720p_cpu1800h_ddr 600_vsfsam.txt
                                for a kernel?
