Sent from my ALCATEL ONE TOUCH 7041X using Tapatalk
MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by scooter2014Proof will be in the pudding.... I have yet to see any andriod device run netflicks 4 k other then those pre approved to do so by netflicks.
Originally posted by scooter2014 View PostNice 31. Dollars for it deal of the week. Clark easy on the trigger..... LOL... He doesnt do it on purpose (ok not sure but I think he doesnt)
Originally posted by trebor View PostFrom Videostrong
We'd like to clarify that information about this device we create in our WIDEVINE Integration Platform Device Management
The Works we have been doing is about DRM, not Netflix
Make: VS
Model: M8S PRO+
Security Level: Lever_1
SOC: Amlogic S905XMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by treborFor those who are keen
MECOOL M8S Pro+ TV Box
coupon: GBM8SP7 $31.69
http://www.gearbest.com/tv-box/pp_656048.html
M8S PRO 905X 2/16 Arrived and you see the L1 but as mentioned nothing to do with Netflix 4k etc is 1/2 the battle but not all, pity
Maximum resolution 720 x 480 Netflix
The BoxBrand: MECOOL Model: M8S Pro+
Type: TV Box
System: Android 7.1
Processor: S905X
CPU: Amlogic S905X
Core: 2.0GHz
GPU: Mali-450
RAM: 2G
ROM: 16G
Max. Extended Capacity: TF card up to 32GB (not included)Decoder Format: AVS,H.264,H.265,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
Video format: 1080P,4K x 2K,ASF,AVI,AVS,DAT,FLV,H.264,H.265,ISO,MKV,MOV,MPE G,MPG,RM,RMVB,TS,VOB,VP9 Profile-2,WMV
Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
Photo Format: BMP,GIF,JPEG,PNG,TIFFWIFI: 802.11b/g/n
Bluetooth: Unsupport
Power Supply: Charge Adapter
Interface: 3.5mm Audio,DC 5V,Ethernet,HDMI,TF card,USB2.0
Language: Multi-language
HDMI Version: 2.0
External Subtitle Supported: Yes
RJ45 Port Speed: 10 / 100MbpsSystem Bit: 64Bit Power Type: External Power Adapter Mode
Power Adapter Input: 100-240V / 50-60HzRemote Controller Battery: 2 x AAA battery ( not included ) Product weight: 0.1100 kg
Package weight: 0.4200 kg
Product size (L x W x H): 10.20 x 10.20 x 2.10 cm / 4.02 x 4.02 x 0.83 inches
Package size (L x W x H): 17.90 x 11.00 x 6.50 cm / 7.05 x 4.33 x 2.56 inches
What's Is the Box
Various Views of ports, Vents
A Slight Design Change Chrome trim with Extra Venting all the way may help with Air Circulation and keeping it kool
Bit of a look at the inners
Top Side
Underneath
Bling
Showing Barrel Antenna and another top view
WiFi Chip
eMMC
Mystery Ram, must be sheepish about the name.
As Mentioned Usual Mecool UI
The Memory situation and Ram situation
Information what we have going on the Inside
Ram Bench test for our Unknown Brand, not to bad
Vellamo Looking ok
Antutu lacking
Ethernet
Wifi
What can be said about this unit
The Good
The Performance appearance and Hardware is good, thermals are fine
Current Price puts it in the Budget range for a 2/16 905x. Android 7
Should do most that any normal 905x can do.
Remote works well. wifi ethernet good at this location.
2 usb ports is enough, (alway want more)
Options of LibreElec, other goodies as it gets around we can hope.
Very early days for this Unit.
The Not so good:
The advertising Campaign that promised and gave not much.
UI, think it's due for an update as its typical of all Meccol.
My unit still had factory testing tools running and all sorts of stuff
No Root can't uninstall or disable at present.
Thanks Gearbest for the opportunity to test drive this unit.
There are currently 2201 users online. 0 members and 2201 guests.
