MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Currently running Magendanz's Nexus ATV rom for the Beelink Mini Mx 3 II...the nicest for this particular box at this time. No wifi or stock remote, but a fast, stable ATV rom all the same. I've written Videostrong suggesting they release their firmware in IMG format (fat hope, I know) and hinting that this would go some way to overcoming the false ad campaign around their box because people will at least feel able to experiment with other roms... Actually if Magendanz added a wifi driver for the M8 Pro Plus, I'd be happy to stay put with it. I suspect the remote is hard coded into the bootloader or kernel since it has power management built in..but wiser heads may know better.
If anyone else starts to tinker with USB Burning tool, note that with some IMGs. you may get an error after it erases the current bootloader. Don't panic. Leave the Tool running with the firmware you want still loaded. Unplug and replug the usb cable pressing the reset button briefly. When you reconnect, the Tool will then continue to burn the rest of the rom successfully...
PS: added build.prop from Superceleron's ATV rom for the Vim, which spoofs the Mibox. DRM Widevine remains at Level 3 but an unexpected bonus is that the Vim IR remote now works out-of-the-box...AND YouTube now plays at 2160p on my 2k monitor, so it will do 4k on the right screen. All we need is to add the relevant wifi driver..what chip does this damn thing use?Last edited by Zahir; 12 July 2017, 16:49.
I ordered this Bluetooth Mi remote and it works great out of the box, for any of my Android boxes. Been using it for a couple of days now, much nicer basic remote.
This remote does NOT have the builtin MIC, which is a shame.
https://www.aliexpress.com/item/Orig...608.0.0.Rx8xKBMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Zahir View PostBINGO! Have solved wifi and YouTube 2k/4k while activating the Khadas Vim IR remote in lieu of the factory one. Now to put it all together on a solid ATV base. Either TX5 Pro or the XannyTech mod might do it.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
So, a smooth ATV rom with root and TWRP that does YouTube in 2k/4k with working wifi and (non-factory) IR remote. SPMC etc etc play gorgeously.. Sufficient unto the day, especially when you consider the crap firmware I started with. Widevine Level 1? To what end at this point?You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Thank you, I received it fine. As I suspected, this remote, which closely resembles the Zidoo box remote, also operates like it: i.e. the remote.conf file is called from the kernel/bootloader and depends on that link. On its own, the file doesn't cause the box to recognize key codes from this remote. I tried several things, but with the same non-result. Appreciate your efforts, all the same.
Sent from my ALCATEL ONE TOUCH 7041X using Tapatalk
There are currently 3189 users online. 2 members and 3187 guests.
