MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
    Originally posted by ElGato View Post
    I get
    E:Footer is wrong
    E:Signature verification failed
    E:error: 21
    Assume E: is error line.
    Possible the upload is corrupt
    let me try to see if it makes any difference from a usb stick
    EDIT : it worked
    wifi on this box is really horrible, i'm getting 13 mb/s on this box... and i'm getting 73 mb/s on my phone (s7)
    both connected to same wifi, and same distance to the router.. hopefully this isn't a hardware, but software issue ..
      EDIT : it worked
      Really? I tried from USB stick. Are you able to create a verification code from your downloaded zip so I can compare? In the meantime I will download again.
        here you go http://i.imgur.com/tWAT6wm.png (sha1 checker built into win10)
        make sure usb is formatted with fat32 or exfat
          Thanks, but just realised I've been a complete N00b. I just copied the USB.zip to the drive instead of extracting the contents. Just about to try again.
            haha yeah that's not gonna work :P
              Was hoping the TV App had been updated to latest KODI. Here's hoping it's more stable.
                Mine updated fine....??? System updating now ill post more
                  Nice rooted now too..... Ok unpack zip....then copy the 3 files from the unpack... Onto sd card unplug install sd card. Press reset switch at front just inside open ribs right hand side. (What Knob designed that at front of box lol) hold it down plug in device will boot up and install firmware..... Yes tried 2 devices working tested WORKING.
                    Root root rooot ok spmc works fine. Kodi you have to uninstall the Bloat ware I do via rpot explorer
                      With root gone remove kodi.tar in system kodi fine...
ID:	658416Click image for larger version
ID:	658411Click image for larger version
ID:	658412Click image for larger version
ID:	658413Click image for larger version
ID:	658414Click image for larger version
ID:	658415Click image for larger version
                          What Happens when you remove that file? Kodi from the playstore is working fine for me
                            Just gets rid of all the crap addons should you push the kodi launcher from main launcher.
                              Scooter, not sure if you subscribe to Netflix, but if you do, can you give this Netflix version a try. If it works, it will give at least 720p with DD+ (Dolby Digital Plus). Hopefully, if it works, it may even give higher resolutions.
                              Thanks.
                                Kk. This one.
