Maybe send a PM or 2
MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by Shkumba View PostGuest Can you please provide a Fix for this firmware V0928-fixed.zip ?
As it stands YOU are the only hope that can FIX our Freezing Boxes!
If you've got one of the bad batch, you need to install M8S_PRO+-20170829.121614.V0321.img (http://freaktab.org/3acc0ea053ee8feb) using USB Burning Tool.
Originally posted by karanchoo View PostHi
i just got my box from bangood and its with 20171124 firmware , can anyone tell me how i can install lean-back launcher , i really like the interface of lean-back launcher on my mi box and dont like the default launcher of meecool , any idea or guide ?
regardsMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest I have tried that several times to instal (http://freaktab.org/3acc0ea053ee8feb) and I was not able to pas 4% on USB Burning Tool. Change all my USB cables but nothing helped. I am so confuse as how you did it that I can't do it???
I would try and place a fan of some sort to see if it may be a heat related issue...Just set a typical 12vdc computer fan under the box and use the 5vdc usb as a power source, fan will run slower than designed,
but it will push air thru the M8S and bring the temperature down. I posted over on the -W thread how I modified my -w to run cooler.
Originally posted by xinxe View Posthello e bought a m8s pro and I want to install libreelec but e seen that the wifi gives problems. Is there any solution for this? Thank you
Hey guys.
So, I messed with the build.prop trying to get the chromecast to work and now the box is stuck on boot. I get the mecool screen, then an mbox animation loops forever. I haven't flashed any custom rom so idk where that animation came from. Anyone knows who I can get into recovery mode? I have no reset button. I tried holding 1 while powering up and it didn't do anything. I also tried burn card maker but without recovery I can't do anything.
edit: I still have the backup build.prop but I don't know how to restore it.
edit2: I just shorted the pins where the reset switch was supposed to be and it entered recovery, all good now.Last edited by fatalerror; 27 April 2018, 08:59.
Hi everyone how has a bad batch of M8S Pro + (Plus),
I almost throw my new box M8S Pro + that had one of the bad batch's and was totally not able to strat e return to life... But now with this firmware it works! It has a bug for Bluetooth but I will refer to post #93 and perform from build.prom I am confident that it will work and now here you have a brand new box with Oreo on Top thanks to this man lewy20041 !
http://freaktab.com/forum/tv-player-...eded-wip/page7Last edited by Shkumba; 01 May 2018, 08:34.
Originally posted by Shkumba View PostHi everyone how has a bad batch of M8S Pro + (Plus),
Thanks for posting this.
MeCool M8S Pro +
I have loaded it on to my original Bad Batch Box and indeed it runs - Great.
but ...
a few little things ... had to install Solid Explorer to edit the build.prop (couldn't get ES to work) but build.prop doesn't have the above mentioned line in it ? not in the file I found ?? Editing in the line did nothing, so had to delete the bluetooth apk and now not getting the fail notice, which is nice.
Have to edit build.prop in
/Vendor
this is the folder which contains the build.prop that needs editing to
config.disable_bluetooth=true
This will eliminate the Bluetooth error message.
Only the Filemanager app sees the USB thumbdrive I have installed.
ES, SE managers and both Kodi and SPMC can't see it as a drive for some strange reason ?
Nice to be able to see a USB drive ...
Difficult to get the file managers to hit the right file as they keep jumping on press ??
No Power button so I installed a simple Power Button app !
All in all way better than a box that freezes after 20 seconds, and very nearly really useable so BIG Thanks Lewy.
Heres hoping Magendanz or someone can make a nice ATV version as well.
Lewy is going to be doing more work soon ....
Thanks again
There are currently 3086 users online. 1 members and 3085 guests.
