[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
    Originally posted by trebor
    Works here fine win10
    Bottom closest to back of box
    Hold Reset button av socket, plug in USB detects...
    Cable USB to USB??
    Enviado desde mi m3 note mediante Tapatalk
      It works, thank you, now better then original image! But the problems within the DTV still remain, goes out of sync. And quit a few other problems. Hopefully Videostrong come with an DTV update soon.
        that is the DTV app, i cant do nothing about it
          No I understand that would have been far more better that they made the code public, because lot's of bad code inside . BTW. I thought it was an error inside the DTV app, when I turned the DTV app on, I got the message from my TV , not supported then I needed to plug the HDMI cable out and in and it worked again, with your img, this problem seems to be solved.
          What I do not like in your and in the original .img is the light colored launcher, in my opinion very bad idea because of the HDMI voltage output, TV uses lot's ot power this way. For the rest good job and nice to have someone on board who cares
            press the home button of the remote on the main screen of the launcher and change is background to a darker one
            I also dont like to bright launchers!
              there is a pity not to be android tv room. it is compatible with android tv launcher?
                Nop!
                  In mine's there is not a buttom in the av socket. The reset buttom is on the lower side.
                  When I press it, USB plug (all of them) and it doesn't do anything
                  I've flashed a lot of Amlogic TV Boxes, but with this one it seems there is some problem
                    when you have the USB side in front of you, the two on the left side and then the one closest to the bottom. And the restart button on the top of the box, as there is only one (1)
                      Thanks. This is the USB that works.
                      It starts the firmware upgrade but at 96% hangs with this error.
                      What version of USB Burning Tool do you use?
                        Finally, I've done the trick.
                        You must to disable temperature range check in View/Temperature menu setting.
                          Not seen that problem, but a handy find,
                          Maybe caused by cable or lower powered/well used USB port
                          If you can find one like this
                          12inches (30cm) works excellent if you find you're burning a few
                          Great success, front usb ports, on my desktop PC.
                          Also have the longer shielded type running form the back of PC
                            View and download from Yandex.Disk
                              Yes i know about that firmware for 1 week now, i already worked on it but i dint like it, it worse than the last one!
                              The only thing good is you can have REAL Widevine L1 if you flash it and then burn the keys... the problem you cant use my custom one without losing that because i dont think i will rls the build that i made with that one!
                              Btw once you burn the keys to your boxes you cant go back... i mean you can but you never ever again can flash again that keys...
                                Thats crazy what if you had system crash and wanted to reinstall just dumb not to be able to flash when you wish..... Seems silly.
