[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
Superceleron as we install your rom without installing the keys in the stock rom so it means that there is no return to give? How has it been done? I have installed rom and then tried to install KI_PRO_AVL6862-ota-20170519.183520.V0321 which I think is the stock rom and I can not get it in twrp says it is not ro.board.platform = gxl. I tried install through the update app and also not
Well its my new one coming... but it will take some time due to the china holidays...
BTW, would you try to make an Android TV firmware? To make posible Netflix in HD.
Originally posted by Txemoto View Post
In superceleron we trust!!!!
Originally posted by Jake360 View PostGot my box,, just trying to figure out what satellites I need to enable for UK freesat
just trying to update to the latest firmware V0923 but keep getting error aborted/failed, i put the usb folder on usb stick, update, local, confirm then it reboots and fails every time,
do i need to root first, and how do i root and add twrp. thanks
EDIT: flashed scv2 instead lolLast edited by Jake360; 10 October 2017, 21:29.
Originally posted by Jake360 View Postjust trying to update to the latest firmware V0923 but keep getting error aborted/failed, i put the usb folder on usb stick, update, local, confirm then it reboots and fails every time,
I think the last versión from September its "KI_PRO_AVL6862-ota-20170905.020920.V0619" and u have v0923.
Regards.
There are currently 3359 users online. 0 members and 3359 guests.
