[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
    Well get this one "KI_PRO_AVL6862-NMF26Q-20170519.183520.V0321.zip" is a IMG inside...
    And then update by zip to the L1 one.
    Thanks! got the widevine on stock rom but now i discovered its impossible to get anyway netflix HD, right?
      superceleron, It would be posible to make an Android TV firmware for this TV BOX like the M8S Pro+ to get Netflix in HD?
      • superceleron
        superceleron commented
        Editing a comment
        well is always possible, the problem is my time lol, i m8 do it in a near future!
        But i cant test it since my box L1 is broken... well it still going to be sometime before i touch this so...
      Why the v2 unrooted?
        because you can root it yourself by TWRP. i recommend Magisk 13.3...
          Thanks, I did not understand chanhelog well.
          auto frame only in FTMC and SPMC? or can I open mxplayer and change?
          Do it has a Bottom bar?
          Is the top bar removed on youtube?
          Can I go back to the original firmware after trying this?
          Thank you
            Thank you
            Everything you need is in the changelog, read both changelogs, never only one!
              "In superceleron we trust"
              Please, can you get some time to make an Android TV firmware with the L1?
              This machine with Netflix in HD would become in the best TV Box at the moment.
                After i get another, my box died on me....
                  Will you buy another one? If not, I can test it for you
                    yes im waiting for confirmation to get another...
                    And thks, but you cant help m8, i do my own tests and my own debug so you cant help on that!
                      Ok. Besides, I've installed DRM Info and says me that my KI Pro has L3
                      Thanks again for your work
                        Yes i know i will fix it after i get a new box to work on.
                        They are out of stock for now! maybe in 1 or 2 weeks!
                          Do you mean that is possible to become to L1?
                          BTW, there is a new version of the firmware with the audio sync problem finally solved
                          Hoy presentamos un nuevo firmware valido para el TV-Box Mecool KI PRO un dispositivo que incluye el SoC de Amlogic S905D, un Quad Core muy similar al S905X pero que está diseñado especialmente para ser integrado en equipos con sintonizadores de TDT y satélite. Dentro tenemos integradas 2GB de RAM DDR4, 16GB de memoria de almacenamiento eMMc, Bluetooth 4.1 LE y wifi aC. En
                            https://androidpc.es/blog/2017/09/14...te-05-09-2017/
                            Well if you have the L1+hdcp keys already flashes then yes...
                            Yes i know that, i already have it here! well when i have my new box.. for now i cant do nothing!
                              When to expect the scv3, congratulations on your work.
