[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
    Originally posted by abbots View Post
    thanks!
    how do I force KI into flash mode, I don't think I have a reset switch in AV socket ? (how deep in AV do I need to do?)
    when I plug USB cable, KI just boots on USB power to normal boot
    Reset pin hole is on underside of box
      underneath power switch, next to leg, AND, covered by small circular (manuf.. date?) sticker ? I think I've found it, thanks
      /later/, no, that has a screw under the sticker...
      the smal hole about half way down on the edge of vents? don't feel any spring loaded switch ?
      /much later/ got it, needed a smaller size paper click, thanks
        superceleron When do you expect your ATV version?
        Originally posted by Txemoto View Post
        This is the last oficial firmware version for the KI Pro
        It has ATV google play and Netflix HD works like a charm.
        unfortunately, the rom is rooted and most of the ATV apps don't work with it.
        Thanks in advance
        I have curiosity, Can you tell us some ATV apps that no work on it because it's rooted?
          Sorry I said "most of the ATV apps don´t work" and I wanted to say most of VOD apps check if the device is rooted to avoid illegal copy of content. In Spain one of the most important VOD providers Movistar+, and doesn't work with rooted devices.
            I'm afraid I've fu==88d up my KI pro, using the Burn Card Maker method as mentioned in post #217. Led stays blue, No display, Does not pop up anymore in Usb Burning Tool. Even Librelec won't boot from SD card. Doesn't boot into recovery modus.
            Anyone witth a possible solution, that might work?
              superceleron , I guess you are still busy. Do we will have the ATV version one of these days?
                Yes very very busy.. i have a dead line until the end of this month to finish a "box" to go to CES... so... busy busy busy
                So dunno if i will work on any custom rom until the end of this month!
                  Thank you for the info. We'll wait a lite more for it.
                    just setting up SCV2, when doing ATV, if you can, please allow for AUS ntp, au.pool.ntp.org if you can
                    thanks
                      Txemoto
                      while waiting for the superceleron rom you can use this (k1pro-ota-vitmod-beta2.1-05102017.zip) search in google.also it is a atv rom.
                        Something is coming this week....
                          We hope you have time to correct some problems that we have commented on in the post.
                          Some important for me is:
                          I can not install modified APKs. I have an apk to modify permissions of the apk before invoking. After passing this program can not be installed in the KI. I think this has to do with - Application signature check disabled
                          - APK integrity and version checking disabled
                          Another is the epg of the DTV apk. In dvb-s2 you only have the current and next program. We need 7 days.
                          And for the ATV version I think that in the end it's a problem for me. Do not many apk works if you put root? Is it like that? Is this solved with Magisk?
                          I would like Netflix in FHD but if that means that I can not have root it is a problem. I need root especially for the application that lets me use the ps3 command as a mouse (for bluetooth).
                          With Total Comander I can not unzip large files. In other boxes there is no problem.
                          Someone else but this is the important thing.
                            Not for this one... is a totally new rom, ATV rom!
                            This one still going to wait a bit longer...
                              Then we hope that the new ATV rom does not have these errors.
                              Thank you.
