All applications get root privileges, unfortunately the superuser or supersu does not regulate the root right, I'm looking for a solution to the regulation.
[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
We are impatient of the new version.
Why Android TV version? what difference there are?
For what I have been able to read the messages you are looking at the possibility of HD in netflix. If it was possible in m8s + maybe here too.
For next version, It would be good this:
- Fix DTV - epg error in dvb-s2 only current and next program. Dvb-t2 ok
- Application signature check disabled
- APK integrity and version checking disabled
- Fix DTV- when switching favorites, it does automatically start the channel list. Not start please.
- Fix DTV- black screen when to give epg button, and load the channel again. Not black screen and reload please
- Fix DTV- When you change the channel in the list position in the epg botton, the channel is changed to that channel. This is annoying This should be like this, changed if I give "Ok botton" over channel but if I go "down" and go "up" cursor to see the information that does not change to this channel.
- Auto frame on all android not only in kodi, spmc or my favorite FTMC
Hi, is the audio sync issue on AC3 satellite channels still present on latest stock ROM or with this one? I used to own KI Plus and it had the same problem. Now I'm buying a new box, was looking at KI or KIII Pro. If it has the issue I think I'm just gonna buy an Enigma 2 for the satellite part and some cheap Android for Kodi and stuff. What would you do in my position?
I had I look at the Klll pro but went for this on price as kl pro does same for cheaper, and Kl pro is newer than klll pro
but if you want to play a few games on it then klll has more ram and higher spec GPU, but for just TV streaming and DTV this box is spot on, I also have a nvidia shield tv but that's in a totally different league
Originally posted by cro2pac View PostYea, I can get KI Pro approx. $35 cheaper (buying on **** from EU so no custom's charges). My main use is DTV, Kodi and Youtube, don't play games at all. Thanks for the input, I think I'm gonna go with KI Pro.
KIPRO - code total 60 euros€.
Originally posted by kafeelazam View Postmy dvb-S2 was not working on stock rom and still not working inis this Rom can anybody solve my problem box reboot after connecting dvb-S2 cable box keeps rebooting until i disconnect dvb-S2 cable Strange issue
There are currently 4426 users online. 0 members and 4426 guests.
