Sent from my Lenovo X3c50 using Tapatalk
[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
Originally posted by kafeelazam View PostCan i have image file of latest firmware
Originally posted by Txemoto View Post
This is the last oficial firmware version for the KI Pro
It has ATV google play and Netflix HD works like a charm.
unfortunately, the rom is rooted and most of the ATV apps don't work with it.
superceleron, finally, will you make an ATV version?
Thanks in advance
And yes i know it have some atv stuff but have lots of problems!
Had the same when using sd car burning tool, once you have released the reset button with micro sd card in pull hdmi out and back in again, only way I could get display back on when reflashing, I just takes a bit of trial and error to get it back up and running, also had to use the stock firmware to reflash after trying custom rom, would boot into recovery but wouldn't flash from recovery
in anticipation of ATV build, tried to install the SCV2-A7.1 from recovery/sd card, but, got:
install /sdcard/SCV2-A7.1-Mecool.KI.PRO.zip
opening update package
verifying update package
verification took 0.1 (result 1)
E Signature verification failed
E:error 21
install aborted
does than mean my download is bad?
the OTA build posted in earlier post KI_PRO_AVL6862-ota-20171030.210510.V0619 installed fine, fwiw
Originally posted by scooter2014 View PostGo to first post and re read it.....
BURNING TOOL FOR INSTALL......
how do I force KI into flash mode, I don't think I have a reset switch in AV socket ? (how deep in AV do I need to do?)
when I plug USB cable, KI just boots on USB power to normal boot
There are currently 2404 users online. 0 members and 2404 guests.
