[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
Originally posted by juliocunha View PostI copied the BurnKeyTools.apk and *.bin files to the root of the USB device and simply enjoy
the widevine key staus: failed,widevine bin does not exist
hdcpkey status: filed,hdcpkey.bin does not exist
I do not realize I put everything in the usb root
What is wrong anyway?
This is if you are on this rom, but bear in mind i dint test this rom as L1 rom since my L1 key is broken in my device so.. in theory it should be ok.. but i dont know for sure!
Originally posted by juliocunha View Postsuperceloron the drm info says security level 3 and hdcp level unprotected. I made the rename but everything is still the same as always .
Superceleron already made a rom android tv based on your rom but it has security level 3Last edited by juliocunha; 27 September 2017, 08:20.
Originally posted by rafik24 View PostMy wifi stopped working too after few minutes of running libreelec and since i cannot get it to work anymore on stock or SCV2 as it does not find any networks.
Any tricks you guys might know ?
When does wifi go, is ethernet turned off in the settings?
Well like i said above i dint test this rom on a L1 box since mine is broken... so you may need to go back to stock if you really want L1... sorry but for now this is the only way until i get a new device
There are currently 2101 users online. 0 members and 2101 guests.
