[ROM] Mecool KI Pro (S905D-DDR4-DTV) Android 7.1.1 - SCV2 (NOT SUPPORTED ANYMORE)
    Originally posted by superceleron
    Updated 1� post with SCV2
    Thanks , you can upload images ? I am o holydays and i cant install
    Enviado desde mi m3 note mediante Tapatalk
      Updated 1º post with SCV2
      • Fixed audio problems in DTV. 100% or 95%.
      • superceleron
        superceleron commented
        Editing a comment
        In mine is 100% tested on my ISP DVB-T/2 channels (From 4k to sd...) and not sound problems!
      #78
      thanks
      Widevine L1 ( Install the Keys to get the proper usage of it, it falls back to L3 if you dont do it. )
      Could you explain this?
      • superceleron
        Editing a comment
        Well you flash the keys that mecool rls for this device.
        Here you go... dont ask me for instructions... is all there!
        PS: this enables HDCP on your device so watch out if you use another device to record this etc..
      #80
      SCV2
      not sound problems in DTV !
      thanks
        Impossible, I am trying to install with USB_Burning_Tool and it does not detect the device.
        I tried with all versions and nothing, before I got to work with v2.0.5.15.
        I'm with Win10 64bit.
        • superceleron
          Editing a comment
          Use the lower usb port near the sdcard slot, keep the reset button few more seconds (7/8secs) pressed and see if it helps.
        #82
        cataplas
        burn card
          And this way you can not load SCV2 Click image for larger version  Name:	KIII-Pro-OTA-Firmware-Update.jpg Views:	1 Size:	48.4 KB ID:	661485 (this is the KIII screen only as an example)
          • superceleron
            Editing a comment
            Nop, that is OTA and i dint rls a OTA but a full img!
          #84
          hi dear
          did you think is wold working on m8s II even have bug wifi i not use wifi ^^
          tanx for helping
          have good day
          • superceleron
            Editing a comment
            Sorry but no, different chips!
          #85
          http://freaktab.org/9f3f09e06b4a66fe
          You wrote this in other post:
          "Yes i know about that firmware for 1 week now, i already worked on it but i dint like it, it worse than the last one!
          The only thing good is you can have REAL Widevine L1 if you flash it and then burn the keys... the problem you cant use my custom one without losing that because i dont think i will rls the build that i made with that one!
          Btw once you burn the keys to your boxes you cant go back... i mean you can but you never ever again can flash again that keys..."
          If i use the new custom firmware i will lost L1?
          • superceleron
            Editing a comment
            No you dont lose it!
          #86
          Originally posted by petras54 View Post
          cataplas
          burn card
          Thanks, I have installed from sdcard, but the sound from CVBS/L/R connector is very low. I use headphones through a chain of music to listen to TV.
            Tx superceleron for the respond but only one think, it is not the s905x forum herre?
            • superceleron
              Editing a comment
              Yes it is, i had to post it here because theirs no S905D subforum!
            #88
            NO Fixed audio problems in DTV to 100%.
            There is a video-audio delay after a few minutes.
            • superceleron
              Editing a comment
              hmm k, all ok in here!
            #89
            two questions to someone using this box:
            In my country (Italy) actually there are a couple of sat channels 4k HDR-HLG (scrambled or not). I would like to know if connecting this box to a tv 4k HDR (but not HLG) it is possible to see this channels in HDR mode (it should pop up “HDR” tooltip).
            The second question is about youtube. Does anyone tested video samples 4k HDR? My tv (LG uh770v) has youtube app but does not support HDR (again, does not popup “HDR” message on start playing video).
            Thank you all.
              How how do you enter cccam lines on this firmware. Is there a secret menu ?
