as always appreciate all your effort. will definetly donate!
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
tillaz87 Could you tell me if you intend releasing a version of (9.0 pie) on GT1 S912. Having a lot of issue with this 7.1.2 of rom running on original GT1 (bluetooth audio buggy and also disney + audio isn't working.., need to reboot box each time for wifi to work..)
Hi!
TV Box - Beelink GT1 Ultimate ( S/N: B706D )
Firmware - MULTI_Z6BASED_ATV10.7.img + Patch10.8.zip
IR Remote control - standart.
Not work IR Remote...
If TV Box turned off, I can turn it on from the IR Remote, but if it’s turned on, then commands from the IR Remote are not executed
replace file remote.conf from origanal firmware - not work
firmware - https://forum.freaktab.com/forum/tv-...both-6255-9377 - work ir remote
how to make the IR Remote control work on this firmware?
KeyTest.apk - not show any command from IR Remote
Does this rom have CIFS support in kernel? i need to mount samba folder from nas to folder on internal sd card
CIFS support is not included but I found out that NFS is. So now I can see NAS share as local folder.- Cand you tell me what script command lines you use??? or How do you did it?
Just a simple explanation of how to mount a folder of NAS into the Beelink
David
Sorry for my bad english.
Today (damn) I update es file manager and now I can't write on sd and usb storage.
I try to use FX to enable but it tells me that "this device does not appear to support the Android Storage Accesso Framework (error: ACTION_OPEN_DOCUMENT_TREE not implemented by device)
Can you tell me what can I do and wich version of ES file explorer works?
Thank's
Huh... I finished read each 190 pages now...
I installed latest 10.7 from sd-card and it looks Ok.
I have some question.
During creation of sd-card I unchecked "erase booloader", checked "to partition and format" and don't changed anything in dropdown box. Is it correct
Should I do everything again with erasing the bootloader and completely clearing the flash?
If I understand right I have to flash 10.8 patch now. Correct?
There are currently 3422 users online. 1 members and 3421 guests.
