[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Novato View Post
Hi tillaz87 can you give me a Help? My device was often having issues with YouTube, so I uninstalled the update. I went to watch yesterday and locked the box so I hung up. I went to watch YouTube again today and locked the box so I hung up. To my surprise it did not start any more, at some point showed the Nexus Logo and in other bao showed nothing. I tried to flash some firmware here with SD Card (I always did so) and it's no problem, the flash does not start. Any idea?Originally posted by Novato View PostLocked = Frozen on YouTube screen. I do not know the correct term for this in English.
kwabh 08-05-2018, 13:32
Hello Tillaz, I am an old citizen of 85yrs using a H 96 box I would be MOST grateful if you would kindly study the possibility( when you have a few free minutes ) to select a compatible image for my android box and please send me the link for downloading.
I must thank you in advance for your generosity.
rgds
Yours respectfully,
No, idea sounds like some hardware died. All I can suggest is flashing with burntool as I've never used card method before.
Originally posted by Novato View PostThis happened because YouTube locked my device twice, I had to turn off the power. The second time Unfortunately the laughter did not show the image anymore.
Also just because your box freezes when using YouTube does not mean its actually YouTube that is the problem, it could just be triggering the hardware to fail.
Take the AX12 batch with faulty GPU for example all 3D games would make the device lock up / freeze
Surely more people would have reported this by now if it wasn't something on your end? sure you stopped it updating automatically??
Hi I tried both with memory card, refi the entire recording process and also with the tool USB Burn Tool. With the memory card method this happens, and with the PC method this happens. In the latter example it seems that it has been solved but at a great cost.
Youtube is working fine with the update uninstalled for the people who have my old box. they use it mainly for Youtube
I can really only talk for my own ROM no idea about others, the base version of YouTube could be diff in that firmware as well as many other things.
Youtube is working fine with the update uninstalled on this firmware for my old box (GT1). they use it mainly for Youtube
So thank you for your help anyway, I did not think it was necessary that I'm using a Firmware of yours to get a little help. Unfortunately YouTube is causing a lot of people, today a guy said that YouTube caught his Mibox by forcing him to turn off the power. In the end I apologize, I was not really using your firmware. I asked for your help because I consider you a charismatic developer.
Originally posted by Novato View PostSo thank you for your help anyway, I did not think it was necessary that I'm using a Firmware of yours to get a little help. Unfortunately YouTube is causing a lot of people, today a guy said that YouTube caught his Mibox by forcing him to turn off the power. In the end I apologize, I was not really using your firmware. I asked for your help because I consider you a charismatic developer.
Also have nothing to go off as no logs or anything have been uploaded..
I only know is its not happening on this firmware without the update. I don't have a box at hand to check either and no one has uploaded any logs.
Originally posted by Greg2506 View PostHello,
I just got my GT1 Ultimate. I wanted to update with the SD card method. I had a very short moment the message "Upgrading ..." then after black screen and since nothing more ...
Can anybody help me ?
Thank you.This is Android TV it supports all variants of the GT1 + other q201 boxes, which means this firmware is much different to what these boxes ship with (Tablet UI)
My recommendation is that you download the Beelink GT1 Ultimate OEM firmware, and try to recover your device through SD Card Maker or PC USB Burn Tool Software.
There are currently 1503 users online. 0 members and 1503 guests.
