[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
tillaz87 This may have been covered, but just want to confirm with you. With this patch, although Android TV OS, I assume that it still won't work with Google Home set up right? I guess no natural chromecast built in. I'm thinking flashing the patch and free up my chromecast from my family room tv which currently hosts the beelink with wired ethernet as well. Casting kid story via google home to family room was the need. Thanks in advance.
Originally posted by GentDiors View Posttillaz87 This may have been covered, but just want to confirm with you. With this patch, although Android TV OS, I assume that it still won't work with Google Home set up right? I guess no natural chromecast built in. I'm thinking flashing the patch and free up my chromecast from my family room tv which currently hosts the beelink with wired ethernet as well. Casting kid story via google home to family room was the need. Thanks in advance.
However I know nothing about google home, I can give you an extra zip to add it back and test with G-home
Originally posted by tillaz87 View Post
Chromecast was removed because we don't have keys from google for it to work properly, only *certified by google* devices have this working.
Volevo chiederti se fosse possibile fare una guida su come si effettua l'integrazione del TV launcher di google su una rom pulita....
Thank you for the work you do tillaz87 especially wonderful ROM !!! I wanted to ask you if you could make a guide on how to integrate the google Leanback TV launcher on a clean ROM ....Last edited by Aces37; 15 January 2018, 16:57.
Originally posted by Wbaldassini View PostTillazÂ* como que podemos colocar os app e apk na tela inicial da v8? Instalei ela + não consigo puxar pra tela inicial!
Going to try this when v9 comes upp.
Also can you fix the inks for the 6255/9377 downloads because i looked at Beelink forum and wasnt sure wich rom for 7.1.2 to download
cheers..
Skickat från min Bluboo S1 via Tapatalk
I have installed this ROM on my Beelink GT1 Standard and it is great!
My only problem is related to using it with an Rii Mini I7 air mouse.
The i7 works really fine except when using the standard on-screen keyboard: in this case I can't select the letter I want since, when I press the OK button to click on the letter, the i7 sends the keycode for the keyboard "Enter" key, instead of the "OK" event for the original, infrared, remote.
Is there a way to remap the "OK" button on the i7?
Otherwise, is it possible to modify the standard keyboard to accept the "Enter" keycode when clicking on a letter? The AOSP keyboard that is included in superceleron's ATV ROM works like this...
Thanks for your work and for this great ROM!
/M
There are currently 2097 users online. 2 members and 2095 guests.
