[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by danj303 View PostAny chance of a version for the B706 serial number box?Originally posted by tillaz87 View PostI've renamed the 96 version to 10.2
Will upload 10.3 soon which uses latest z6 firmware (kernel) then i'm moving on form here.. maybe I will be back if Orio pops up for s912
Hello to everyone!!
I have a problem and I wonder if there is someone that can help me.
I've created the micro SD with the OS as the instructions said at the first post and I inserted it to my TV Box but it never went into recovery, instead it booted normally into my current OS.
The following steps from the instructions never happened to me when I insert the micro SD card in my Amlogic device and power it on:
1. You will be able to enter into recovery and the firmware will be flashed automatically.
2. When the TV BOX reboots
3. Remove the micro SD Card, this step is very important, wait 4-5 minutes and the update will completed.
I don't know what I did wrong.
Is there a specific way to boot my device from microSD?
Thank you!!
I tested it before uploading and it works providing you didn't mess with the system prior to flashing the zip
Removing system stuff etc
Could you please provide previous version of this patch ( with added nav bar)
Originally posted by Cebulix View Post
I just flashed your 10.3 firmware and then this patch via recovery and i get this error all time cant skip it or do anything
This is the previous version it just includes *Fix recant apps FC*
only thing I can think of is your flashing it on wrong rom
Just a Q about using flashify app instead of twrp. Many peeps have used flashify directly from rooted stock firmware to backup and flash kernels, and custom firmwares. I was wondering if flashing your 10.3 rom by keeping my existing stock boot loader and 7.1.2 kernel would allow the 2gb/3gb forks to allow memory to be allocated? It may allow a work around for those wanting 3gb when only half is accessed. To me it's just a visual thing, as it has no bearing on performance and operation.
There are currently 2936 users online. 3 members and 2933 guests.
