[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Originally posted by izzy1971 View Post
tillaz87 thank you , it worked. i restored the recovery. however when going in wireless OTA update it is stuck at 200% because the first time i try to do update when unit rebooted it try to goto TWRP recovery and now i am no longer able to receive the update. any idea how i could clear the OTA folder so it restart from beginning i search the OTA folder and found one but it was empty. not sure why it is stuck at 200%
factory reset will clear the cache though and the 200% problem.
Before I purchase another box and Netflix, does the beelink gt1 supports Netflix 1080p and 4K? I know that with stock rom it doesn't but what about with this rom and the others one listed here? PS: I have already a beelink gt1 but I don't want to waste the trial if it doesn't support 1080p and up. Thanks
Originally posted by Samekas View PostBefore I purchase another box and Netflix, does the beelink gt1 supports Netflix 1080p and 4K? I know that with stock rom it doesn't but what about with this rom and the others one listed here? PS: I have already a beelink gt1 but I don't want to waste the trial if it doesn't support 1080p and up. Thanks
No 4k without widevine L1 + hdcp 2.2
Get the new xiaomi mi box 4 if you want 4k netflix etc, or a shield tv
I can't find the Mi box 4 anywhere ? And it's the China version right?
Mi 4
You probably want to wait for international version
the old one is also very similar some even say better
https://www.geekbuying.com/item/-Off...ox-381148.html
Edit:
Don't buy Chinese version, not same firmware as international
Mi4C
Mi 4
There are currently 1609 users online. 1 members and 1608 guests.
