[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Its not lower res.. apps built for TV just use 320 DPI.
This is because your normally sat quite far away from your TV on a sofa.. The image on the left would be harder to read at that distance, especially at 4k.
Your best using a non ATV ROM, standard android is intended for phone/tablet which are inches away from you so app are not enlarged
You can do all that with xposed on 7.1.2 as well plus more.
But, if your yet to test 7.1 how do you know that you prefer a base of 6.0.1 over any other firmware ?
Most don't like it, but it what works with my stock KK Samsung tablet, even when comparing to all the custom CM (MM & LP based) firmwares available. I keep telling peeps most issues are google related not Samsung, but they continue to bash TW and Samsung. Killing hidden google services is the only way to kill battery consumption and CPU utilisation in idle and in background tasks. I could use hacked google services or work around, but none are 100% compatible, especially when updates are needed. Heck even when over clocked to 1900mhz allows me to get 10 hours battery time continuously, when stock at 1600mhz and Google services are left alone, I barely make 8 hours.
Then there is head to head firmware comparisons between 6.0 and 7.0 on real world speeds, and 6.0 ended up being better. I laughed when KK was introduced as better than JB. It took some time in my part to identify google services did not play as well in KK, thus the radical methods to selectivly stop services that run even if not used or disabled in settings.
click the boot card maker link on first post
I've created the micro SD as the instructions said and I inserted it to my TV Box but it never went into recovery, instead it booted normally into the OS.
The following steps never happened to me when I insert the micro SD card in my Amlogic device and power it on:
1. You will be able to enter into recovery and the firmware will be flashed automatically.
2. When the TV BOX reboots
3. Remove the micro SD Card, this step is very important, wait 4-5 minutes and the update will completed.
I don't know what I did wrong.
Originally posted by X92-2GB View Post
I am old school, basic no frills os for clean operation, after all, the app is what i notice, not what's on or not on my home screen... Mainly stripped down of unnecessary Google apps and services. Plus I don't use many utilities to control the operation of apps and theme, such as Tasker, Greenify and others.
Updated v10.3- Re-based on latest vorke release
(Download ~> ARCHIVE) Flash Burn Package With Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by tillaz87 View PostUpdated v10.3- Re-based on latest vorke release
(Download ~> ARCHIVE) Flash Burn Package With Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.220180126 firmware was less buggy than previously versions ?
Initially I want to thank and congratulate you for the fantastic work you are doing with this ROM.
Today I installed version 10.3. Perfect, except when managing memory.
I have the GT1 Ultimate A706DS (3gb RAM and 32gb ROM), but its ROM only manages 1.7 GB as total memory.
The original Beelink ROMs (both the 707D0 and 708DO) correctly manage the 3GB of memory.
Any solution perspective for this problem?
Originally posted by isfontes View PostInitially I want to thank and congratulate you for the fantastic work you are doing with this ROM.
as far as we know its a bootloader problem so not possible for me to fix on vorke firmware
There are currently 1584 users online. 0 members and 1584 guests.
