[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
I am running a modded kernel, and have found that I cannot use advanced features like I can with stock. Once I enable all the developer debug tweaks in my build.prop, playback is not so crisp.
I am now playing around with stockish build.prop, light on the mods. Added Google dns, and basic known and required build.prop edits for fixes with playback.
I find unless you have a true 4K TV, keep your settings to 444 8bit, and YUV. If your set to 422 color space, your opening a can of worms, as content should be 444. You may be forcing the box to convert from 444 to 442, and having the TV convert back to 444 internally, depending on its capabilities and settings.
Originally posted by tillaz87 View Post(Download ~> ARCHIVE) [/B]Flash Burn Package With Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Thank you for this firmware.
Should I download all .img files or just the last one "MULTI_Z6BASED_ATV10.7_Discontinued.img" please?
Originally posted by tenoce View PostHi,
Latest version of Youtube ATV version keeps crashing after I start it. Had to downgrade it to have it working. Is anyone else experiencing this?
Google have changed something :/
I think s912 is dead on amlogics side, no 8.0 update.
This is a decant buy though for any new comers.. might grab on myself to have a look
It's certified ATV by Google so has Chromecast and L1 and an WiFi antenna.. but uses the weaker 905X
If anyone is interested, you may notice YouTube, Netflix and Google Play services all have updated within a week. I put the blame on Google play services, as just about every update punks my systems. Sometimes it effects my tablet and of recent it has made my streaming apps puke. Nat Geo, FX Now, YouTube, Xfinity Stream, and a few others needed data cleared or just reinstalled. I did not want to bother installing the latest beta of play services, as homie don't play beta.
Would revert to previous play services but have resolved all my issues.
ALSO NOTED... since play services update, some build prop tweaks break some streaming apps from play back. RTE for example, will JS error or fail to connect. I am thinking Google is locking down on root detection, namely Xposed on 6.0 on up android.
for me, this method works
I'm looking at picking up the MECOOL KM8
its Google Certified Android TV and has a WiFi antenna..
8.0 but is the 905X.. s912 appears dead on amlogics side
I'm grabbing one just to be nosy but I would say it's the best option for Android TV for price right now.
However I have been told to expect something from Google in October so..
Edit:
About YouTube, Google have changed something.. I've not had a chance to look at logs so no idea what exactly. Not sure if I will get around to it either as this box was passed on.
If someone posts logcat of the crash I will have a look though.Last edited by tillaz87; 01 August 2018, 18:38.
There are currently 3139 users online. 0 members and 3139 guests.
