Sorry, i don't understand.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by Greg2506 View PostHello,
I just got my GT1 Ultimate. I wanted to update with the SD card method. I had a very short moment the message "Upgrading ..." then after black screen and since nothing more ...
Can anybody help me ?
Thank you.
The method that always works is 'PC USB Burn Tool Software' that allows you to completely replace the firmware with another one with different characteristics. In my TV Box I have to disconnect the HDMI cable to be able to update the firmware, and see the process from the PC.
Hello,
I am stuck. I flashed my TX8 box with USB Burning Tool but I flashed the bootloader because I could not do otherwise (Uboot blocked the flash if I do not erase the bootloader). When the box starts, I'm directly on TWRP and I can not do anything else. I flashed with the stock of ROM tx8 but the box does not work anymore, it stays on recovery. What can I do?
Thank you for your help !
(Sorry for my english)
Hello, Thank you for your reply ! But it did not work. I flashed the ROM stock TX8 with a total flash (bootloader ..) but once the operation is finished successfully the box does not work. It lights up, I have the logo and directly the recovery I have this message: impossible to load volume / misc I do not know what to do knowing that this is the TX8 ROM stock. Do you have an idea?
Originally posted by killer0692 View PostHello all, i have Just a little question... Will we have a rom with Android tv 8? Thanks you very much
09-08-2018, 08:27
Originally posted by zagor View Post
Does this rom have CIFS support in kernel? i need to mount samba folder from nas to folder on internal sd card
Originally posted by X92-2GB View Post
I use a 3rd party app to connect to my network storage. Though I recommend FTP as SAMBA is super slow on file transfers.
Originally posted by jrfol View Posti have a S/N B706D and installed this ROM, my bluetooth and wifi is not working, have any fix? I have already seen some comments here from users with the same serial number and reporting working normally
Read This Before Posting- For root just reboot recovery then -> Advanced / Magisk root
- Look here if remote does not work with keyboard or Gamepad is not working
Problem with a video streaming app? Look here before posting- Support patch for Led clock on vorke devices (Flash this after rom)
- If you want to block ads use this or flash this
- For Bluetooth issues on QC9377 or LMT8830 flash this Do not use on AP6255
There are currently 4443 users online. 0 members and 4443 guests.
