[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by tillaz87 View Post
    this works but you only have 2GB RAM
    Thank you so much for the quick answer, can you please post the link again, I can deal with just 2GB of RAM
      links on first post
        links on first post
        Thank you, I understand, I asked again because those links are so confusing, I click on archive link you have and there are 6 firmwares do download, i just thought since you are the expert, you could have made it easy on me the basic user and just post the correct link i've begged for. instead of going back and forth for no reason.
        But thanks I get the point.
          Mate its straight forward.. the archive contains every version released, they go up in numbers and dates so should be obvious 10.7 is the latest and last release
          not to mention first post says
          Recant Changes: v10.7 Final release
          • built Magisk root method in to TWRP (Advanced/Magisk root)
          • Fixed TWRP reporting 5.1.1 OS, some zip like xposed fail because of this
          • Busybox updated / fixed
          • reverted some lib stuff
          • Fixed auto frame settings?
          • USB Camera fixed?
            Tell me please. Why the minimum frequency of the processor is 500 mgz. Can I put 100 mgz. Sorry for my English.
              Why would you want to set it to 100mhz? It's not a phone so battery life isn't an issue.. most modern CPU min is 400mhz
              Having it at 100mhz will cause lag on the home screen as leanback launcher has a lot going on.
              but your free to set it to what ever you like
                Thank you for response. Will the processor tempreture go up because of 500 mhz? Could you tell me please how to get 100 mhz.
                  Hi, if you want to listen youtube/youtube embed music site in the background as https://8tracks.com/ outside the US you can:
                  1) Download Firefox browser (not the Android TV version): https://www.apkmirror.com/apk/mozill...-apk-download/
                  2) Open and install with Firefox this addon: https://addons.mozilla.org/en-US/fir...ound-play-fix/
                  Enjoy.
                    I tested many min from 100 to 1000..
                    temps where always the same 49 to 55c but much better performance at 500, sorry but if you want to change stuff with my rom you will have to figger that out your self as I don't recommend it or intend to help make it run worse
                    If 100mhz min was a good idea it would already be like that.. it's simply to low when starting tasks or exiting back to home screen
                    100mhz wouldn't be be used much anyway because of the interactive govenor but when it is (starting app/exiting to home) you see lag / stutter as it has to crank up from a frequency which is far to slow
                      tillaz87 have fixed HEVC 10bit playback in your ROM ?
                      i'm asking because i asked other rom developer here what i heard from some other forum http://freaktab.com/forum/tv-player-...881#post723881
                        Hello, thank you very much for your ROM.
                        I have a S912 box HIMEDIA H7 (detailed Chinese). The basic operation of your ROM is perfect
                        but the Bluetooth remote control voice button does not work. This remote control is similar to MIBOX (detailed).
                        Can it be repaired? what can I do?
                        PS: I'm from China. This post is translated by Google. I hope you can understand it. I look forward to your reply. Thank you
                          There is also a problem that the wired network does not work. The model is RTL8211E
                            Is it possible to add samba support for sharing with windows protocol?
                              Thnks for your cooperation.
                                There are corrections for this on page 1 above the main post.
                                About the unmapped buttons you need to identify which key layout your control loads and after finding edit it. I did something a few pages ago.
