[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tis View Post
Originally posted by Novato View Post
I've always known that this icon was not meant to open the app drawer, but let's face it it's a lot more beautiful than App Drawer's, lol. There is and speaking of that I wanted to ask you one more thing, I do not know if you could do it for me. But I wanted to be able to replace the power options icon with what's coming in NVIDIA Shield, but every time I edit and replace the app it triggers bootloop. I've attached the icon in question, could you make the replacement for me?
https://mega.nz/#!QmogWTTL!9SKET_klE...KJs6dywwq6wpVY
drag and drop it into res/drawable-nodpi-v4/
You're welcome! These are very simple mods although mapping all the buttons on the Air Mouse was laborious. As for new versions of the firmware this will depend exclusively on the time and interest of tillaz87 in keeping things up to date. I'm noob more than you! lol
Easy way was just to ask tillaz what remote he used and buy the same
I've had quite a few boxes and by far the worst remote I've used was for the GT1.
I looked into this last year before tillaz posted his guide on the first page and it jst seemed too much hassle.
Hello..I can not find a solution to my problem. .. The power key of the remote control does not work ...I changed to the files of .remote.conf and .kl (with the files given by tillaz87) .. My box is Beelink Gt1 with 2/16 and 10.7 rom version and my remote control Minix Neo A2 lite ... I do not want to change with the other learning remote controls because my remote control is very beautiful ... I hope it is a solution to my problem.
Originally posted by exotic34 View PostHello..I can not find a solution to my problem. .. The power key of the remote control does not work ...I changed to the files of .remote.conf and .kl (with the files given by tillaz87) .. My box is Beelink Gt1 with 2/16 and 10.7 rom version and my remote control Minix Neo A2 lite ... I do not want to change with the other learning remote controls because my remote control is very beautiful ... I hope it is a solution to my problem.
First use an app like Gamepad Test to see which player would be supported by your remote control. Now you should know which file "vendor.kl" your remote control needs. Then go to the Minix umufirmware, go to the system / use / keylayout folder and copy the file identified in the first step, copy and paste in some storage to use later in your Berlink GT1. Do the same with the file remote.conf present in the system / etc / folder, with the two files in hand take your BeeliBe GT1, make a copy of the original files, replace with the new copies of the Minix firmware, seven permissions and restart your device. If this does not solve the problem, you may need to identify how your Air Mouse Works. In my case, utioxos the Air Mouse MX3, it has two connections with the device, the first is by Infrared, the second is by 2.4G Wireless USB Dongle. That way it is impossible to connect the device when it is using the Wireless connection, but when I use the Infrared connection it connects. Ha is the control Minix is very functional, being of the brand Minix ends up having more quality, but I do not think it's a bit pretty, lol.
Originally posted by jotascotch View PostHow to upgrade 10.6 to 10.7? With TWRP? Does it flashes img files? I'm on 10.6 and don't want to loose my data, apps...
Thanks.
This remote is made for minix box so you wont ever be to power on the box with this remote as are bootloader dose not have the IR code for its power button.
contact minix for the correct remote.conf those people in that forum I linked you to post incorrect stuff.. hence the reason for Patch1
with correct remote.conf it should work while box is on look back 50+ pages for a user name KodiSocks I helped them get this working while box is on
There are currently 4401 users online. 1 members and 4400 guests.
