[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by CheckMate View PostI asked beelink support to send me a link of the original firmware because I don’t have it anymore...
btw there is only prob with WIFI, the BT works fine.
Code:cd /sdcard
Code:dmesg >> dmesg.txt
Originally posted by tillaz87 View PostV11 later on today which will most likely be final release. its working great for me. after this I'm disappearing from the forums for a while
will this new ROM still be uploaded? I know we shouldn't ask the eta
Download terminal app then enter
Code:cd /sdcard
Hey, I'm testing this rom and this is what I've found so far
- If you switch off wifi while using ethernet, some apps tell you that you are offline (I've seen this in other roms)
- Autoframerate switching on Level 1 doesn't do anything and level 2 reduces the screen to 24fps (as expected) but the videos are skipping a lot of frames. Also, when you stop playing a video, it still keeps de 24p setting instead of going back to 60p. The only rom that this works is android 6 from superceleron
- I can use my air mouse remote control with the on screen keyboard. The "OK" button isn't accepted as a mouse click. In every other app or setting the "OK" works. It just doesn't work with the on screen keyboard.
- It's missing a browser. I can't download anything like a file explorer or aptoide, I have to sideload everything
- When the cpu is under heavy load, the mouse cursor stops moving / stutters (probably something related with the cpu performance governor)
- On 1st kodi startup, the app crashes and you can't choose "close this app", you have to restart the box
- The mouse cursor is too small @ 4k
Do you have a github repo so that someone could have a look at those issues?
Originally posted by Alianato View Post
what do you mean ???
Originally posted by Don_Pachuco View Post
I mean that I would much rather prefer a ROM that isn't Android TV based, so I could use my preferred launcher, and be able to have Kodi as an app icon, be able to use my Chrome beta browser, and other apps that i ran for performance. ATV sucks because it doesn't allow you to use the box as any other Android device.
and because this rom looks nice I wouldn't mind to have a similar one but not ATV
Originally posted by TigTex View Post- I can use my air mouse remote control with the on screen keyboard. The "OK" button isn't accepted as a mouse click. In every other app or setting the "OK" works.
Originally posted by TigTex View Post- It's missing a browser. I can't download anything like a file explorer or aptoide, I have to sideload everything
Originally posted by TigTex View Post- When the cpu is under heavy load, the mouse cursor stops moving / stutters (probably something related with the cpu performance governor)
Originally posted by TigTex View Post- On 1st kodi startup, the app crashes and you can't choose "close this app", you have to restart the box
You can still use all apps anyway you just need to side load them and once you have aptoide you have access to all apps
But Magendanz + others have that type of rom anyway
could just use one of them really
There are currently 1529 users online. 0 members and 1529 guests.
