[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View PostAnyone with 706D want to try something to help understand the ram problem?
my serial number is A706DBDH, successful with burn card, never got the the usb tool to work
i want to reset all the way back to the correct, original beelink firmware to see if my lost gig suddenly re-appears.
besides that, what do you propose?
Ah so it's a wired controller and not BT?
When the gamepad is plugged in can you do this from terminal and tell me if you see your device
cat /proc/bus/input/devices
If its detected a .kl might be enough.
Otherwise we won't be to update the module as we don't have the kernel source for this rom and xpad.ko is built into kernel on this firmware.
If you rename your xpad.ko to xpad2.ko can you insmod?
I already created a .kl file for my device but it was not showing up once the .kl file installed :-(
The only solution I found for the moment was binary patching the kernel in order to replace an existing product/vendor id in xpad driver with mine. It works, but any update of your rom will require me to re-patch the kernel (not that fun...).
I'll flash the original kernel and try to insmod a renamed xpad.ko module to see what it does but I'm not very optimistic since the driver name is hard coded in the xpad.c source code.
I think I'll have to patch the kernel each time a new update is released (or wait until vorke update their kernel module).
Originally posted by mperreir View Post
Yes, wired controller but with custom product id / vendor id...
if yes then just swap my ramdisk with one in your patched boot.img
When the gamepad is plugged in can you see your device with
Originally posted by Twisted714 View Post
has anybody tried this?
Originally posted by Clayman_32 View Post
I install Vorke original firmware (Vorke_Z6-20171221) and I have 2GB but box works great (antutu score 49.900)
3D is broken on that because of openGL I had to fix it. in fact I just gave them the fix yesterday on their freaktab forum
Just ask me if i made any changes to ramisk with any updates, if no then you can just restore your patched boot.img with twrp after backing it up
Concerning the output of cat ./proc/bus/input/devices, now that I have patched the kernel of course I can see it. But I guess you would like to know if it shows up when I use the original kernel no ?
By the way another question (not only for you Tillaz87 but for all : how do you all deal with the default read only access that current android version enforce for SD and external devices ? On non android TV ROMS applications can ask external device write permissions through the builtin android file manager. But it does not seem to work on android TV (at least FIle Commander tells me "there is no application to perform this action" when I try to do so). The other solution is to install Xposed framework and a module that allows write access to SD but I'm wondering if some of you have other / better solutions not involving Xposed framework.
Originally posted by mperreir View PostBut I guess each time Vorke will update its ROM we won't know if they have changed the kernel.
I see new hardware from these Chinese OEM coming very soon with 8.0 as the selling point, they then forget about z6 like the others before it.
Concerning the output of cat ./proc/bus/input/devices, I guess you would like to know if it shows up when I use the original kernel no ?
Installed 10.1 yesterday. Huge improvement from 6.0.1. My TV suddenly looks updated. Thanks a lot, tillaz87
Few questions: Can I cast live NHL streams from chrome on my android phone to GT1? If yes, how?
This ROM seems to be based on Xiaomi box. Just curious if the Shield TV was an option (Can be used as a plex server?)
Thanks,
Vab
There are currently 3223 users online. 1 members and 3222 guests.
