[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by Guus View PostI have tried both yahoo and openweather but yahoo let me set my city while openweather not. Both doesn't show meteo on home screen widget... I'll try to delete cache of the app and see
Originally posted by zickler View Post
thanks for the reply. i do have the original remote but had the minix neo lying around and used it instead. so with the original remote everything should work fine right?
Originally posted by mrish View Post
Just tried it, same result. I had cleared cache/dalvik cache too post flashing.
Also, I somehow feel this has got something to do with the screen rotation functionality which has been removed in your versions. Do you have the files from 707NO that I can directly replace/add after your patch to regain this functionality?
I tried to use Amlogic Rom Customization tool to unpack 707NO for extracting screen-rotation related files, but it is giving me some weird JDK error.
Cheers,
Can you send me link for the apk your using for prime?
I can provide a universal quick and easy (lazy) fix as a zip for all these air mouse if some people don't feel up to making them for their remotes.
The trade off is the enter key on a physical keyboard will be DPAD_CENTER
in the generic.kl i would simply change
key 28 ENTER
key 28 DPAD_CENTER
Originally posted by tillaz87So, the standard prime video apk wont work on any android TV as its broke when tv_core_hardware.xml is used
The stock ROM has a tablet config which uses tablet_core_hardware.xml
You can see by flashing this, which has it work but brakes android TV stuff look .zip
flash this to revert look .zip
its no wonder piracy of this type of media is so big on android boxes...
What do you mean about brakes android tv stuff?
I've used Amazon prime video with magendanz rom or with your V6, I'm sure... probably with magendanz Android TV. It's the first app i tried and i watched a small part of a tv series
are you using a modded apk or something? I used latest version from market.
Originally posted by Guus View PostWhat do you mean about brakes android tv stuff?
Originally posted by tillaz87 View PostSo, the standard prime video apk wont work on any android TV as its broke when tv_core_hardware.xml is used
flash this to revert [ATTACH]n694270[/ATTACH]
http://freaktab.com/forum/tv-player-...ms-android-7-1
sure you weren't using the normal version of his ROM? what apk also?
I will test his rom but from the logcat error and seeing what brakes I would be surprised as every ATV devices has to use tv_core_hardware.xml
using tablet_core_hardware.xml makes ATV app incompatible
There are currently 3022 users online. 0 members and 3022 guests.
