[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hi all
I'm new on this forum. Actually I'm running V8 in my GT1 Ultimate and I've a few of questions.
How to use multitasking here? I cannot activate neither android action bar nor notification bar, any chance to have them?
How to check memory status and clean system and applications? I cannot find anything like Clean Master in Play Store, any alternative?
How to set on the weather widget available in home?
thanks
thanks
multitasking = double press home button
action bar/notification bar = just not part of ATV
How to check memory status and clean system and applications = bad habit, honestly. but apps can be killed via multitasking if they crash
How to set on the weather widget = Lclock app in app draw, use openweather as source make sure location is on (wifi/network)
Originally posted by SocksKodi View Post
Same with me. Tell me if you find a fix please. Thanks
For me, V8 is better than V6 (no more freeze after long time without been used).
I paired again my remote after the update to V8.
The only trouble is that my remote is not able to power on the TV after a long time without been used.
So I use my stock TV remote to do it and after everything is done with my Rii Mini, even power on or off the TV
Really such a good rom tillaz87 !!
https://play.google.com/store/apps/d...saver&hl=en_GB
Originally posted by El Holandes View PostHi! Amazing job at V8. I got a question about unroot. Can in unroot with supersu? Should I be worried when it asked me to get the factory boot image? What should I do! I would like to install Magisk! Thanks
Enviado desde mi iPhone utilizando TapatalkLast edited by tenoce; 19 December 2017, 10:17.
Originally posted by tenoce
I couldn't root with Magisk, but was successful with Super SU. From the reboot menu chose recovery, and flash latest SU.
Thanks. But I think the rom is already rooted and I haven’t flashed the supersu in TWRP. Thats why when I try to flash magisk I get ERROR:1. My question is if I have to unroot it first with supersu, and then I can root it again with Magisk. And also I would like to know how I have to unroot it with supersu? Thanks everyone
There are currently 2823 users online. 1 members and 2822 guests.
