[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by kole View Postv9 with firmware vorke v6 will you it 32 or 64 bit?
The vorke z6 patch will be uploaded but is to be taken as is. it wont be updated. that new OEM firmware has stuff that annoys me and its not worth fixing
Originally posted by SocksKodi View PostI think it changed something. I'm trying to manually use remotecfg in terminal but the problem is that the device is now rooted. Fix the patch and I'll keep trying
it shouldn't matter though, if your remote.conf doesn't work with that boot.img it failed and can only be done on linux by using dtc command on _aml_dtb then making the change and flashing result
There are currently 1438 users online. 0 members and 1438 guests.
