[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    z6 patch is starting to look and feel better than beelink, its getting there..
      Originally posted by minonano View Post
      tillaz
      Thanks for the tip on closing opened apps, everything working ok except caststreams app (watching NHL hockey) Keeps closing, any idea why? Thanks
      https://caststreams.com/
      Will look at logcat
      Most likely using assets not supported in ATV reading this
      I will look though, when i get time. best to contact the dev as they have the source and can fix
        I've been busy studying for college do you still need me to test that patch? And does anyone here recommend any advancedsettings file for kodi?
          And tillaz, I'm setting a box for my brother when do are you thinking in realesing the next updates? Should I keep it for a couple of weeks and wait?
            Originally posted by tillaz87 View Post
            Will look at logcat
            You mean contacting beelink? I forgot to mention that it was working with the stock rom.
              No, the app developer. they need to support android TV as its also not working on shield TV
              it works on stock as that's not android TV its normal android for tablet/phone
                Not sure yet, trying to fit this in with the project at work so time i have on it can be limited
                  running V8 here on my GT1 Ultimate. cant wait for V9. thank you for all your hard work tillaz87
                    Originally posted by minixfreak View Post
                    Great News For 9377 Wifi users..... here is the remote fix so you can add other remotes but only works for 9377 wifi users http://www.mediafire.com/file/b406jq...otefix9377.zip .... also here is the zip for amcodec fix http://www.mediafire.com/file/zruux1...amcodecfix.zip
                    Did you get the rom to work on the h96 pro +?
                      yes it will work
                        tillaz
                        Hi. Thank you for your work. I slightly corrected the translation (for Russian) of the TvSettings application. Maybe you want to update the translation in the next build
                          yes it will work
                          Can you explain to me a bit how you installed it? Thank you.
                            Got 3D antutu working with the vorke z6 patch
ID:	699843Click image for larger version
                              WOW! Real pro!
                                I've tried the v8 and it's spectacular. The only problem is that Netflix does not work, it gives an error. Some game also gives problems. Is there a solution for Netflix?
