[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hello guys,
i installed Android TV and it looks very good BUT
...any chance to remove tiles from home screen, do not show tiles of installed but not recently used apps?
if they stay in app drawer only - it will be fine!
For example - i install Ace Stream Media, Leanback keyboard, SD Maid Pro... and so on, but i dont need icons/tiles of that apps right on homescreen!
Originally posted by hussein View Post
Howcan I get the image and how to burn it?
Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by tillaz87 View Post
Images are on first post
Unfortunately, it did not work. Windows could not detect the USB connection to the GT1. Can I flash the image through TWRP as it is available in my GT1 through recovery mode.
Originally posted by tillaz87 View PostUploading v9 now...
My main priority is the z6 rom though as its now running better than this patch, and have been able get more done with it like re-partition for extra 1GB on data for apps as well as boot.img changes..
ChangeLog V9:- ATV PackageInstaller view
- New soft power menu (no longer needs root)
- Sign in can now be skipped
- ATV video + audio Codec config files
- Amlogic codec + other library perm fixes
- Play games removed from system, its updated to frequently
- Un-rooted by default
- Magisk can now be installed + safetynet pass (follow these instructions)
- Other stuff I forgot about, its been a while..
WARNING: V8+ IS NOT COMPATIBLE WITH V7 YOU MUST RE-FLASH STOCK 7.1.2 FIRST (Here Is The Download ~> ARCHIVE)- Download the 3 files from the archive above and copy them to the root of Internal Storage (Outside of all folders) Not Micro SDcard!
- Install the terminal.apk or download one from the market
- Open the terminal app and type the commands below pressing enter after each
There are currently 1010 users online. 0 members and 1010 guests.
