[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by ojerez View Post
With the official 7.1.2, Netflix work. Not in HD, but yes in SD
Originally posted by tenoce View Post
I'm using TerrariumTV apk instead.winning
Originally posted by Xenas View PostDoes the V9 fixes the 3D benchmark or 3D games issues ?
Originally posted by hussein View Post
I have reflash image "GT1_707N0_AP6255.img". However, I get now just a green screen when I turn the GT1 on. Then, I flashed "GT1_109M0_AP6255.img" and it worked but it is android 6.0. What should I do next?
Originally posted by Aces37 View Postperfect and working !!! I waited for this moment to see if the magisk hide worked ... but nothing ... tim vision and others do not go..many libraries drm google..ora I know I ask too much @ tillaz87..but you can integrate in the rom the libraries that google has released for Oreo 8 is to adapt them to v9? otherwise you have to wait until the new ROM comes out
Originally posted by hussein View PostI have flashed "GT1_704N0_AP6255.img" and then did an update. Now, I have done also the upgrade to google TV. Everything is fine except Netflix is given error ui-800-3. Any clue on how to fix Netflix.
Originally posted by christofer1234 View PostAfter updating to V9 from V8, i did a wipe and now i am stuck in Google logo and i cant seem to figure out a way to boot normally again. Is there any rom to flash in twrp that will help me or should i try amlogic update tool with stock firmware? thank you
Guest
Hi and thx for this job !!! Sorry for my english (i'm just French
I have a GT1U A706D0, I have update with the new 707D0 (beelink). Can I put your ROM android TV 7.1.2 6255 ? I don't understand exactly how to do it.
Is it right ?
I need to put GT1_707N0_AP6255.img (is it possible with SDcard ?)
and only after I put GT1_Multi_ATV_7.1.2_V9.zip using terminal.apk on the box ?
Thanks for any information you can
give me.
Originally posted by Mathieu73460 View PostHi and thx for this job !!! Sorry for my english (i'm just French
Is it right ?
give me.
Guest
Thx for your fast answer !
If I want to go back on android 707D0 (not TV) , I can do it with my SDcard and the beelink files ?
There are currently 2931 users online. 0 members and 2931 guests.
