[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by steja View PostI don't know why, but on my S912 2GB (QCA9377), WiFi keep lose connection and buffering a lot while streaming spmc/kodi from my PC/NAS.
Never had that on v8 or so.
(707 build, same as v8 before)
Any fix for wifi or so?
Originally posted by ojerez View PostHi. Yesterday I put the v9, but I auto updated YouTube, since it has activated the automatic updates. Do I put the v9 on again? Or better put the original 707 and the v9?
Originally posted by ojerez View PostBy the way, the safetynet does not happen to me. I have the wifi QCA9377
Originally posted by tillaz87 View Post
Install magisk and in its settings enable system-less hosts
or if you want ads just delete system/etc/hosts this will require root though so might as well just do magisk thing.
You need to use stock 707 firmware for 706D I will add to first post in few mins
Hello Thanks for the tip... I was able to resolve with the root and the hosts editor and delete the entries
Thank you
Obrigado
Originally posted by kole View Postlink is out
Originally posted by tis View PostWorking well, thanks tillaz for your work.
Can I remember you saying a few weeks back that you were waiting for delivery of a Mecool m8s Pro L ?
Originally posted by craser View PostI've been trying this rom for two days on my box alfawise h96pro plus. I must say that it works well, even if it consumes a lot of ram. sometimes the system is a bit slow. Do you have any solution? the spotify application Android version occasionally crashes.
what use would it be to always have 1gb free? I never understood why people on these forums feel more free ram is better. I normally have about 500Mb free which is normal on a 2GB device.
I've personally not noticed any of this, and always have 55 games and about 10 apps installed. did you do clean install?
maybe wait for z6 based ROM its performance is better.
There are currently 3315 users online. 0 members and 3315 guests.
