[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by met67 View PostHi,
I have installed this ROM on my Beelink GT1 Standard and it is great!
My only problem is related to using it with an Rii Mini I7 air mouse.
The i7 works really fine except when using the standard on-screen keyboard: in this case I can't select the letter I want since, when I press the OK button to click on the letter, the i7 sends the keycode for the keyboard "Enter" key, instead of the "OK" event for the original, infrared, remote.
Is there a way to remap the "OK" button on the i7?
Otherwise, is it possible to modify the standard keyboard to accept the "Enter" keycode when clicking on a letter? The AOSP keyboard that is included in superceleron's ATV ROM works like this...
Thanks for your work and for this great ROM!
/M
Originally posted by SocksKodi View Post
I don't think mine does that if I understood you correctly
If he has a remote like my H1, if you press the button to disable the mouse and then not use the remote for 30ish seconds it sleeps, so the next time you press a button the mouse is working again.
Can be a pain in Kodi etc
Originally posted by tis View Post
Socks leave tillaz alone, I'm hoping he's busy working on the v9
Originally posted by tillaz87 View Post
Does that remote auto turn on the mouse function on after a while.. even if you had turned it off?
I'm trying to find one that does not do this.
Just be aware that there are two different versions with the same name: one is an air mouse, in wihich you move the pointer waving your hand, the other has a trackpad on top and lets you control the pointer moving your thumb on It. They are identical, the only difference being some sort of drawing of a hand waving a remote in the air mouse version.
I'll try to create a keylayout later this week and let you know.Last edited by met67; 17 January 2018, 14:53.
If you mean that the mouse pointer is activated by itself, then no, It is activated only by the dedicated Key on the remote and stays in or off until you press the key again.Â*
Just be aware that there are two different versions with the same name: one is an air mouse, in wihich you move the pointer waving your hand, the other has a trackpad on top and lets you control the pointer moving your thumb on It. They are identical, the only difference being some sort of drawing of a hand waving a remote in the air mouse version.Â*
I'll try to create a keylayout later this week and let you know.Â*
I don't know if this can be a general solution, since it looks like that those IDs are used by a lot of vendors for different products.
AW thanks for your help, you solved my problems and now my box is perfect :-DLast edited by met67; 17 January 2018, 14:53.
There are currently 3017 users online. 1 members and 3016 guests.
