[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by tis View Post
    Will try later using power lead once box has connected to laptop.
    Thanks mate.
    Success mate, thanks again.
    Using USB Burning Tool 2.0.9 with both erase flash and erase bootloader ticked.
    Connected to laptop by inserting pin into hole on base of box and connecting male/male usb cable.
    Switched on mains power to box.
    Press start and flashed in around 3 minutes
    Just waiting for your latest release now tillaz87
      Thank you, i'll try it tomorrow
        To fill perfectly my tv screen I've to reduce screen size to 92%, is it normal that each time i reboot the box I've to repeat the procedure because setting is not stored?
          does your TV have a 'fit to screen' option? i have not came across this problem myself
            No, it doesn't...it is an LG 55"
            • Guest's Avatar
              Guest commented
              Editing a comment
              Yeah, my LG has the same issue. I just set it to 92% and never have to mess with it again unless I do a factory reset.
            Same with my old Panasonic. However I need to set it to 91%.
              Can you change aspect ratio on your tv? It should be 16.9
              My old lg from 2009 has a fit to screen option but dont think its actually called that on LG i will have a look.
              if my samsung has it turned off its the same most tv do have this option though its just named differant
              will have a look see if i can find out
                Here for LG i think its "just scan" option you need
                link
                Here for panasonic looks like its the "just" option on them
                link
                Just try all the options till it fits screen
                  Help library: Learn how to use, update, maintain and troubleshoot your LG devices and appliances.
                  It is in 16:9 it's just in overscanned. Unfortunatelly there is no such function as "just". NB. the TV is 10 years old. It only needs to be set once to 91% then it stays there, so it really doesn't matter.
                    Anyone else prefer the cock/date and background like this
                    Click image for larger version  Name:	Screenshot_20171121-154349.png Views:	1 Size:	260.2 KB ID:	687506
                    Compared to This
                    Click image for larger version  Name:	Screenshot_20171121-153553.png Views:	1 Size:	306.3 KB ID:	687505
                    Also added soft power menu I built from source
                    Click image for larger version  Name:	Screenshot_20171120-152815.png Views:	1 Size:	297.0 KB ID:	687507Click image for larger version  Name:	Screenshot_20171120-170201.png Views:	1 Size:	255.2 KB ID:	687504
                    better settings menu (Droid TVSettings no longer needed)
                    Click image for larger version  Name:	Screenshot_20171120-152832.png Views:	1 Size:	527.5 KB ID:	687508Click image for larger version  Name:	Screenshot_20171120-152838.png Views:	1 Size:	368.8 KB ID:	687509Click image for larger version  Name:	Screenshot_20171120-152913.png Views:	1 Size:	528.3 KB ID:	687510
                    Update might be a couple of days now as there are other things I want to look at and am away to watch the football soon.
                      Compared to This
                      1st one is better
                        Agree, I also like the 1st one!!
                          link
                          link
                          fixed these links they weren't working when pasted raw. might be of help
                            1st one is better
                            can you add weather to home screen?
                              Hello
                              the first is much better
                              whether new build, he hides can be optimized?
