[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
After installing NoATV patch, I've lost root and recovery is not accessible any more. Anyway I have a problem with virtual keyboard. It is not resposible - I've try with usb air and also with classic mouse and none of them works. But everything else is superb, Rom is very responsible and fast. So it will be nice to share also a noATV .img file.
Originally posted by X92-2GB View PostJust a Q about using flashify app instead of twrp. Many peeps have used flashify directly from rooted stock firmware to backup and flash kernels, and custom firmwares. I was wondering if flashing your 10.3 rom by keeping my existing stock boot loader and 7.1.2 kernel would allow the 2gb/3gb forks to allow memory to be allocated? It may allow a work around for those wanting 3gb when only half is accessed. To me it's just a visual thing, as it has no bearing on performance and operation.
its the same on stock beelink they just choose to show 2GB rather than amount after reserved
Never knew ROM could be flashed with flashify, but no that wont work unfortunately already tried using bootloader from 706D0Last edited by tillaz87; 13 March 2018, 16:22.
Originally posted by H-Tab View PostAfter installing NoATV patch, I've lost root and recovery is not accessible any more. Anyway I have a problem with virtual keyboard. It is not resposible - I've try with usb air and also with classic mouse and none of them works. But everything else is superb, Rom is very responsible and fast. So it will be nice to share also a noATV .img file.
or side load Gboard or flesky
You lost root because it wiped data its normal.. just flash your root method again
Originally posted by philou669 View PostI have problems with a Logitec Harmony bluetooth keyboard. the connection got lost any time. after updating the bluetooth does not work at all. impossible to activate bluetooth the on / off button always remains gray.
There are currently 2907 users online. 0 members and 2907 guests.
