[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Hey tillaz87,
    I finally was able to make the ATV ROM work on the box after not selecting Erase Bootloader in USB burning tool flashed over the stock Beelink Rom 7.1.2. which stopped working after the recent 708N update.
    The new ATV rom is very stable and I am happy with it. All apps work fine but I wanted to know if it is possible to increase the resolution of the sideloaded apps which become very difficult to use with the air mouse as the interface is huge in size to navigate properly. I don't want to flash the non ATV patch lest it may have problems.
      Originally posted by viky1181 View Post
      Hey tillaz87,
      Can you show me some screenshots of what you mean?
        Originally posted by tillaz87 View Post
        if the framework-res.apk has same public.xml as this, it would work properly, but I don't think its systemUI what is the problem.
        Try using stock framework-res.apk and build.prop and let me know
        do i need replace framework-res.apk with stock one and install it ? and build.prop just replace the file
          what is the difference between MULTI_ROM_V10BETA.img, MULTI_Z6BASED_ATV10.1.img and MULTI_Z6BASED_ATV96.img.
          what is the best for a bellink Gt1 Ultimate G912.
          Tanks
            Hello to everyone!!
            I want to install the latest patch and I don't know how. I'm currently running the version 9.
            Can someone please tell me step by step what I have to do in order to install it to my Beelink GT1 Ultimate AX12 TV Box?
            Do I have to buy a special USB cable in order to flash the ROM to my Box?
            Thank you!!
              Originally posted by iliasv82 View Post
              Hello to everyone!!
              Thank you!!
              click the boot card maker link on first post
                I found an annoying USB firmware bug if it detaches and attacks the USB stick the box will restart. You can check? the box is very good. autoframe level 1-2 what does it mean?
                  Hi Guys,
                  I have a Beeling GT1 (A912) and I tried to flash the hardware with tillaz87 image through sd card.
                  The updating process ran for one second and after that nothing was shown via HDMI.
                  I have tried to recover also with another image but nothing happens.
                  Could you please help me?
                    Hello
                    the same thing happened to me, it was the sd card that was not good ... I replaced with another of 16gb that I had and problem solved
                      Originally posted by kole View Post
                      Hello
                      Hi kole, you were right! I used a 32Gb SD and it works. Now I've another issue: Netflix doesn't work and there is no app for Amazon Prime Video.
                      Have you got any suggestion?
                        Cool .... Netflix does not work because the beelink not planned for ... By cons on previous pages I posted a link and @ tilliaz87 for Netflix but sd functional quality .. For Amazon I must have on my pc but I'm not at home
                          On standard non ATV the app is like in left picture and on android tv the app look like the right pic with low resolution.. can something be done to increase the resolution of sideloaded apps...
                            I have yet to test 7.1, but on 6.0.1 you can use Xposed with app settings module to adjust dpi, resolution, orientation and many other modes per app. One reason why I prefer a base 6.0.1 over any other firmware, as there are so many ways to customise and work with phone, tablet and tv apps without having to hack launcher, system ui, and build.prop files.
                              Its not lower res.. apps built for TV just use 320 DPI.
                              This is because your normally sat quite far away from your TV on a sofa.. The image on the left would be harder to read at that distance, especially at 4k.
                              Your best using a non ATV ROM, standard android is intended for phone/tablet which are inches away from you so app are not enlarged
                              You can do all that with xposed on 7.1.2 as well plus more.
                              But, if your yet to test 7.1 how do you know that you prefer a base of 6.0.1 over any other firmware ?
                                I've renamed the 96 version to 10.2
                                Will upload 10.3 soon which uses latest z6 firmware (kernel) then i'm moving on form here.. maybe I will be back if Orio pops up for s912
