Update: I done it! I assigned for yellow button the CleanUp application. Thank you, tillaz87, very much!
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by dimon4ik86 View Post
I have read this manual, but I as a layman feel that as cumbersome and thought there is an easier way to solve this problem
1) Download a terminal app, have the remote connected
in terminal do
cat /proc/bus/input/devices
tell me Vendor= Product=
for the air remote
Originally posted by tillaz87 View Post
The problem is the people who make the air remotes program them wrong. the guide I posted is the right way to fix.
in terminal do
for the air remote
Hello everyone
I'm trying to install the latest version on my GT1 ultimate.
I used the SDcard method, formatted the card and flashed the ROM on it
The card is being read on the stock 7.1 ROM through a file manager
The problem is that when I enter recovery while having the SD card inserted, the update process doesn't begin.
Am I missing something?
Last user said they had to format the card to fat32 for it to work
I have a 64GB sd card, I wasn't able to format it to FAT32 partition
I used EasuUS partition manager to make it work.
Applying update nowLast edited by KamaL; 21 March 2018, 11:40.
Originally posted by tillaz87 View PostHow many people here use a physical keyboard ?
I'm actually having problems pairing my BT keyboard with this rom. It is a cheap keyboard (Silvercrest), but I had no problem in pairing it with the stock ROM and also with my tablets and phones.
When pairing, I type the password on the screen but it says "Wrong password", and I'm sure I've typed it correctly.
Any clue on what may be causing this?
Rui
Originally posted by ramblefish View Post
Hi tillaz87. First of all, many thanks for putting together this ROM.
Rui
Have you tried pairing threw the *more settings* part?
Yes. I've tried both on the quick settings and on the "normal" settings. The result is the same. I've tried after rebooting, caps on/caps off, to no avail... always says the pass is not correct.
Nothing regarding BT function has changed
it should not be asking for password non of mine do, you have tried from TVsettings?
In any case, I will try to get some screenshots tonight so I can explain it with more clarity.
Not sure exactly what you mean by "TV settings" ... you mean pairing with the TV set itself?
There are currently 2766 users online. 0 members and 2766 guests.
