[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
i want to update to 10.5, can i flash it on the file patchnoatv?Last edited by dimon4ik86; 24 March 2018, 21:07.
Originally posted by tillaz87 View Post
Do this
I did as you instruct me and copy the recovery.img into the internal storage then opened the terminal app and enter the code. Then the following error appeared.
dd: unknown operand img
1|once:/ $
I'm not familiar with dev work, I'm an end user so I don't know what I did wrong.
I have TPRW custom recovery that came with your first ROM if that helps.
Can I install the recovery.img of the new 10.5 ROM from an app called "Flashify"
Is there an more convenient way for an end user like me to install the ROM?
Thank you again for your good work.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by iliasv82 View Post
Hello,
1|once:/ $
Thank you again for your good work.Code:su
this is odd what if you just don't add a code? (press back or something) Your keyboard must be paired at the start as it lets you enter the code with it
Also are you now using 10.5 from other day?
I'm on 10.4
Originally posted by Pinki View Post
Amazing, with UGOOS AM3 2.0.6 automatic framerate switch/automatic resolution switch is working properly with Kodi on my Beelink GT1 2GB.
Tillaz87 can you add this to your android tv rom? Playback options from 10.5 are buggy and doesn't work
How it works: when i play 4K HDR movie 23.976fps my tv switch to 3840x2140 23.976, whenn i start fullhd movie its change to 1920x1080 23.976 (depends of movie fps)
Code:su
Unfortunately I had the same results... See the pic attached and tell me if I did something wrong...
Can I install the new 10.5 ROM from TPRW or it must be from stock recovery only?
Please help,
Thank youYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello Tillaz87
Please help,
Thank youCode:su
hes using the very old beelink based rom think Magisk has problems with that boot.img
JoseM can you test this and tel me if led clock is working? on z6.
Flash in recovery https://www.dropbox.com/s/h48af8gfn5u53e1/Pach.zip?dl=0
Originally posted by tillaz87 View Posthes using the very old beelink based rom think Magisk has problems with that boot.img
btw this code is included in this patch right ? ( /sys/class/leds/fd628_dev/) https://github.com/tanixbox/tx3mini_...ed_control.txt
There are currently 6684 users online. 2 members and 6682 guests.
