[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by JoseM View Post
not working i think LED service (LcdStatus.apk) is missing
btw this code is included in this patch right ? ( /sys/class/leds/fd628_dev/) https://github.com/tanixbox/tx3mini_...ed_control.txt
its just for Jose as he has the z6 and since this is been used on more devices now I would like to bring support for hw led clocks back
Hello,
Thank you Tillaz87 for your help & time spending for my issue
I root the device with the latest SuperSU via TPRW and then tried the code you told me and got again an error...
I want to say that I was at official Beelink stock ROM 705D when I installed your ROM (via the terminal app)
The recovery image that I downloaded and have into my device's internal storage is from 708D.
I don't want to spam the thread anymore with my useless posts, can I flash your new 10.5 ROM via PC with my current ROM & recovery (TPRW)?
Please help me,
Thank youYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by kole View PostHello
the command 'su' is to use when one installs a beelink rom ..... on the other hand to install the rom 10.5 it is necessary to use either USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2 before the flashing and not directly with twrp
So I have created a sdcard with Tillaz87 ROM 10.5 and I'm currently running one early Tillaz custom ROM with TPRW recovery.
What I have to do in order to install the new 10.5 ROM?
Thank you
Originally posted by iliasv82 View Post
Hello,
Please help me,
Thank you
You have -> . img
it should be -> .img
OK,
Thank you
It's just because of the space between the ". img" leanback keyboard puts a space when you use . just make sure to do back space so there are no gaps
You have -> . img
Please check if kole's answer will help me too. I think you told me that TPRW can't install your new 10.5 ROM.
KOLE ANSWER:
After having used bootcard make so that the 10.5 is flashed, must put on a card sd of 16gb the files had with bootcard make .. You put out the box and disconnects the food, you insert the SD card, with a paper clip you press on the reset at the back of the box and you put the power while still pressing reset ... Android appears and you remove the paper clip ... That's it
Thank you!! I will do so...
KOLE ANSWER:
Code:reboot update
If you setup boot card maker with this rom you would just insert the sdcard then open terminal app and do
Code:reboot update
There are currently 2181 users online. 0 members and 2181 guests.
