[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by JoseM View Postdon't know if anyone had this problem before (i can't give a sd card permission (only can read files from it) this error (Warning android was unable to display the required permissions screen) maybe it's magisk 16.2 bug or maybe my sd card is broken tillaz87 do you have any idea why ?
Originally posted by tillaz87 View Post
I doubt its big enough, on stock the system partition is 2GB alone.
8GB card is the min I would think. But I would just buy a male to male USB cable.
i have root (permission granted in magisk ) i'm using Root Explorer right now will try ES file explorer
this was blocked by google since 5.1.. Beelink actually just reverted this in the 708 update but it requires changes to the the vold binary from source
Originally posted by iliasv82 View Post
I have a 16Gb SDcard too. I will flash there the ROM and try again. Do I have to press the reset button if the setup from the SDcard doesn't start when I power on the tvbox?
There are currently 1204 users online. 1 members and 1203 guests.
