[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
tillaz87 I have flashed v10.5 Great ROM, however I flashed StockWallPatch.zip and it did not change the background.
Originally posted by tenoce View Posttillaz87 I have flashed v10.5 Great ROM, however I flashed StockWallPatch.zip and it did not change the background.
Frame rate switch is broke in latest vorke z6 firmware so 10.6 has been put off until I have time to look at fixing it.
This will be put on hold though as I'm doing some work elsewhere in my spare time so will have to get back to this
Originally posted by tillaz87 View Post
Clear data for leanback launcher in future it will be included in the zip
This will be put on hold though as I'm doing some work elsewhere in my spare time so will have to get back to thisLast edited by JoseM; 29 March 2018, 18:42.
Originally posted by JoseM View Post
chmod 666 /sys/class/display/mode ?
but all my free time is going on the Nubia z17 Lite that geekbuying sent me so once I release that firmware I will update this.
Originally posted by bodays View PostHello guys,
First of all, thanks tillaz87 for this job... You rocks man!!
I have installed the rom to my beelink GT1 ultimate, but I'm facing a wired issue because youtube is crashing in recurrent modeknowing that I even not touching it.
Some would have a solution for this?
Thanks guys!
added that already still not working its broke in kernel from latest z6 firmware, it works with older stock..
Originally posted by danxc View Post
On the Amlogic boxes video quality and auto frame rate (operational) uniformity can be achieved only with one SMPC (with amcodec) or any other reader, which in turn uses the Stagefright library (MX Player HW, Vimu without Vimu engine, etc.). At the moment SPMC is the most important player on the boxes with SoC Amlogic. I will not describe in detail the reasons in detail, they are listed several times in the topic. On Ugoos AM3 with IOS 2.0.5+ system auto frame rate SPMC works perfectly, without intermediate switches in the winding and with the support of the entire frequency spectrum, including fractional (except interlaced video). At some point, SPMC will be replaced by the official version of Kodi from Google Playb,but the Amlogic box is not yet ready due to a problem with the so-called "modern" auto frame rate (which runs through the system API). The owners of the Minix Neo U9-H are luckier, their box already works perfectly with Kodi.
it broke auto frame switch completely at least in my testing..
also since the the amcodec fix (libamcodec.so added to public.libraries.txt) people have reported amcodec working with kodi.
Like said though I already ported the settings from Ugoos AM3 2.0.5 for auto frame switching but the rest appears to be in the kernel so not looking good for porting the rest
odd I use YouTube a lot not had any crashing. you using the no tv patch?but I learn quick
NOTA: The wired thing is that I'm even to using youtube... right after flashing, at the first boot : "Youtube crashed!"
again, and again... sometimes the message si changing by saying "Youtube is carshing continuously"
For the moment, I have deactivate youtube.
There are currently 2169 users online. 0 members and 2169 guests.
